WTB: Delco Bose Gold Series Amps
Started by smokuspollutus, May 05, 2020, 06:22:24 PM
smokuspollutus
Hi all, looking for a set of Delco-Bose Gold Series amps from either:
89-93 Coupe deVille /89-92 Fleetwood Coupe (must be from a 2-door model)
91-92 Allante
All Allantes had this system standard in the above mentioned years, with it being optional on the deVille and Fleetwood. I only need the amps, but will take the whole enclosure if that's the way them come. Would like to get a complete set of 4 in one shot. Working/non-working condition is not important, as they will be getting re-capped regardless.
Would prefer to buy via Paypal, but could work something out if that's not an option.
Thanks!
Anthony
gkhashem
My 1991 Eldorado has a Bose Gold system with a CD that was restored by me.
So why would not this fit also?
1970 GMC C1500
1992 Oldsmobile 98 (OCA 1st)
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
1966 Coupe Deville (Sr #861)*
smokuspollutus
George, the intended new home for the amps will be my 1984 Eldorado which has 4 4.5" Bose speakers, as does the Allante and Coupe deville.
The downsized Eldo/Seville Bose speakers are an oddball size in the front that allow them to sit in the door without protruding too much, and use 6x9's in the back. The amps will work but don't have the capacitors in the right place to drive the 4.5" properly.  Little too much bass in the back, and not quite enough in the fronts when coupled to 4.5" units.
smokuspollutus
Update, only searching for 91-92 Allante rear units at this point. Thanks so much
Anthony
smokuspollutus
Disregard; found what I needed. Thanks
