1952 wheel studs
Started by Rdtreur, September 07, 2020, 02:36:35 PM
Rdtreur
Hi, I need new wheel studs and nuts for my 1952 series 62 coupe. No need for fancy correct ones, different threat is no problem. I want them 1/2 inch longer if possible . They just need to fit the axle in the rear and the drum in the front.
Any help would be nice
Many thanks, Ramon
R.D. Treur
Past caddy’s:
‘68 convertible ‘70 Eldorado,  ‘75 sedan, ‘75 Fleetwood
Should be able to get at any parts store, like NAPA.
Rdtreur
Thanks, but I’m in The Netherlands so I need a threat size an knurl (?) size and things like that to order longer studs from rockAuto...
R.D. Treur
Past caddy’s:
M. Bankes
Hi,
I have brand new ones here that I can send you, they are the correct thread and size ect but they are original length as well, If they would interest you just let me know
Michael
Rdtreur
Quote from: M. Bankes on September 08, 2020, 06:04:44 PM
Hi,
Michael
Hi Michael, thanks for Trying to help me out but I don’t need original ones but a bit longer. You can help me out by giving the outside diameter of the knurl. I got one front wheel stud out and one rear stud out and it seems that they have a slightly different outside diameter ? Is this correct or is this how they should be?
Many thanks, Ramon
R.D. Treur
Past caddy’s:
