1966 Cadillac 429 exhaust manifolds wanted
Started by caddydaddy1960, December 25, 2020, 08:39:12 PM
caddydaddy1960
Hello,
I need to replace both exhaust manifolds on my 1966 Cadillac SDV with the 429 engine.  They seem rather hard to find, at least in my search so far.  I'd like to work on this project over the winter.  Please contact me if you have any for sale or know where I might find a pair.
Many thanks,
Michael Heinz, Director (#27227)
West Michigan CLC
1960 6337 Coupe Deville (sold 12/20)
1966 68339 Sedan Deville  (sold 2/22)
1974 C6EL67 Fleetwood Eldorado ELC
Director, West Michigan Region CLC
CLC #27227
Bobby B
Michael,
Hi. There's some on eBay, But WOAH  :o......I would've never figured that they would be ASKING that much for them. Maybe someone here has some. Good Luck.
                      Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
May want to run through the period interchange and see if any others fit, if scarce/costly.
Barring cracks, missing, etc, if just in poor shape, consider having them ceramic coated.
I'm sure the "usual suspects" should have a set.
Jeffrey Burland
Since Cadillac didn't share with other divisions until about 1967, these exhaust manifolds are 65-67 429 only. They usually crack when the heat riser rusts shut and heat backs up. If it doesn't crack the manifold it usually backs up to the heat baffle tube in the intake manifold and crack the underside of intake manifold at the point where the tube is the lowest. The left / driver's side. I might have a few left and will message you. thanks, Jeff
Jeff Burland, Just one guy with too many 54-76 restorables and parts to list
https://www.facebook.com/WillingtonCadillac/
caddydaddy1960
Thanks for the info, gentlemen.   My manifolds are both badly cracked.  Jeff, my email is:  caddydaddy1960email addresses not permitted
Happy NewYear!
Michael
CLC #27227
savemy67
Hello Michael,
If you determine that buying replacement manifolds is too expensive, you may want to consider having the crack repaired.
Generally, it is difficult to use typical welding processes to repair iron manifolds.  However, some old-timer welding shops know how to do this kind of repair using brazing techniques.  I would think that being in Michigan, you can probably find such a shop.
Here is a link to a product shown being used to repair an exhaust manifold from a Cadillac 429.  I have never used the product, but the concept is similar to brazing.
https://www.youtube.com/watch?v=taL2IAHkwjM
Repsectfully submitted,
Christopher Winter
Christopher Winter
1967 Sedan DeVille hardtop
