1958 Rochester Fuel Injection
Started by spoon, January 09, 2021, 05:05:48 PM
Quote from: spoon link=topic=163139.msg485092#msg485092 date=1610888955 Spending most of my career as a GM development engineer, I saw much of the progression from carburetor to direct injection./quote]
What department(s) were you in?    Something people would think of as exciting like drivetrain?  Or maybe seemingly less exciting like making the fake wood look less fake or getting the headliners to stay stuck?
spoon
Worked for GM Powertrain initially and moved later moved over to platform development for BOC/LAD doing powertrain and powertrain/chassis mount development. I worked on manual drivability on several programs where I worked with the powertrain calibrators resolving drivability issues.
I have been a FAST fuel injection dealer and do calibration work for my customers and COMP referrals since 2005 . I have raced the attached fuel injection C4 Corvette since 2001 after giving up on the Q-jet that I had raced for since the 1970s.
That sounds like fun.   I was sorta hoping to hear you were the guy that thought it was a good idea to have all those clips holding the hard lines that makes them rust through so I could complain and know who's name to be yelling tomorrow when I'm under the car in the cold replacing a rusted out brake line.
spoon
Quote from: spoonBruce The greatest gains with modern fuel injection came primarily from the ability to do two things. Understanding the actual position of the piston during the combustion cycles and the mass density of the air/fuel mixture during those cycles. That said, these benefits were initially done primarily to improve combustion efficiency to make the EPA happy. What it eventually did was allow the reemergence of more volumetric efficient performance. Spending most of my career as a GM development engineer, I saw much of the progression from carburetor to direct injection.
If you were on the scene, perhaps you could describe how the development of EFI
for the Cosworth Vega (75-76) evolved into the Cad 75-79 EFI?  I have never heard
anything of that development, but it is quite evident from the circuitry that they are very
closely related.  The Cad advanced a lot and achieved ECU parts interchangeability,
the Cosworth ECUs were adjusted and assigned to a specific engine.
I used an Air Sensors FIRST in 1989, with analog computer coupled to their MAF sensor.
Operation was impressive, but when the car went away, the EFI went on my shelf (it is
still there).  Now is AirSensors is making FAST?  Bruce Roe
spoon
Bruce
Give me a call sometime. Share what I know. Not the Shell answer man with all the answers but I don’t mind sharing what I do know. My number is up above.
Quote from: spoon on January 18, 2021, 04:31:45 PM
Bruce
I see no phone number, maybe deleted?  You can email it to me at bcroe@juno.com
Bruce Roe
spoon
Still making progress but its going a little slower than I would like. Some of the parts are not available like the gaskets attached. Fortunately I have the material and the tools to make them. I have attached a few pictures of the progress.
spoon
Now you just need that one thing that goes below it and then the thing that goes behind that and the thing those things bolt to then you can go for a drive and see if it really works.
spoon
Pretty sure it works. It last resided on a dyno on a 390 engine at Cadillac engineering 62 years ago. I have had multiple conversations about the history of this manifold with the development engineer. Some of the stories are pretty hilarious.
Not being a Cadillac guy, it won’t be me to see it run again.
HiRev
To Bruce W. and all else who may have info.
Some time before 1992 a southern California RR mechanic friend bought his wife a beautiful used dark blue de Ville with a white top that he was tickled over. I didn't see anything special till he opened the hood pointed and said "its a five hundred (512?) with mechanical fuel injection." Factory mechanical fuel injection. Then he just let that sink into me.
I wanted the car bad then, but wife said not for sale. When he moved his shop out of state he sold the car in the process without telling me. I've been looking for it since. Never seen or heard of another like it.
Your discussion at least gives hope I'm not living some hallucination. I can't even find a VIN identifier digit for a mechanical fuel injected engine.
Any body here seen it or even one like it or even heard of it?
Thanks for any info you may have.
Cadman-iac
Quote from: HiRev on July 03, 2023, 01:58:14 AMTo Bruce W. and all else who may have info.
 What year was this car? And just so you know, the 500 engine was only available from 1970 thru 1976. It was available with fuel injection, but it wasn't mechanical, and offered between 1973 and 1976 if memory serves.
 Rick
CLC# 32373
My guess, it was a 76 with Electronic Fuel
Injection, or possibly a late 75.  Neither
that system or the 50s mechanical had any
feedback loops, and the ignition system was
just stock.  The 50s system did not even
have the advantage of an electronic air
sensor (MAP), or any sort of compensating
calculations.  Bruce Roe
A Deville with a 500 would be 75 or 76 and I believe mid 75 the EFI became an option and I think was available on all the cars. The first one I saw in person was a Fleetwood so I know a few made it into other than Eldos.
The 75-80 system was electronic but didn't use any microprocessors.  Their new system that came out in 80 in some models did and they made a big deal about that and called it DEFI, D for digital.  The DEFI was basically the same system that GM started putting on other things in 82 but those were never known as DEFI. Cadillac actually stuck with that system on most models till 90.  They did appear to drop the D from the name in the 85-88 range.
The 75-80 system was also multiport meaning there were 8 injectors which is quite different than the DEFI and most other GM systems of the 80's that had 1 or 2 injectors in the throttle body.  Mopar and Ford also played with throttle body at first but quickly changed to multiport unlike GM that wasn't all multiport till 96 which was almost 10 years later than the others. A different twist on multiport was tuned port which I think was a Corvette thing around 85 that then slowly made it to other models including the Allante.
So especially back in 92 for a somewhat technical person I can see them trying to point out that having a multiport EFI system on a 75 or 76 model was unique and different than many of the other EFI systems that would have been around in 92 especially in GM circles.  If you were a GM family in 92 there is a pretty good chance you still had a carb in your daily driver fleet.
I don't know that many people that were not into Cadillacs knew that Cadillac had any sort of fuel injection system back then.  I don't think the average person ever heard of fuel injection other than maybe in a song till the 80's when it ended up in many models.  If car enthusiasts knew about it it was most likely in the context of Corvette even though there were other models that had the same system and a couple electronic systems that were tried.
Calling it a 512 is odd but it sounds like you are not sure that was the number.  512 would be 050 overbore which is probably possible but not common on one of these engines so if someone did it I could see them bragging about it.  A 030 overbore would be 507.  The other number that gets thrown around a bunch is 501 and 502 since those numbers were on the underhood sticker in a fairly large font.  Those numbers were just some sort of identifier for emissions and people never seemed to read the 'fine print' just below that that said either 472 or 500 cuin.
You also mentioned a white top?  Convertible?  If it was a convertible that would make it an Eldorado.  71-76 only the Eldo was available as a convertible from Cadillac so 500", EFI, and convert would be a 75 or 76 Eldo.
Cadman-iac
  Yeah, I wasn't sure what year that Cadillac began using fuel injection. I was remembering a car that my boss had back in 1982, and for some reason I was thinking it was a 73, but I do remember that it was a Fleetwood.
 Somewhere out in my collection of literature, I have a factory manual on the injection system, but I'm not sure what year it was printed. I keep thinking it's 73, but it may be 75. I'd have to dig it up to verify.
   Rick
CLC# 32373
Somewhere in my stuff I have a manual dated 75 that says its a preliminary service manual for electronic fuel injection.  Its been a while since I looked at it but I don't remember it saying anything about the cars it went into.  Personally I have never seen any 75's other than the early 76 Sevilles that had it so maybe they were just trying to get the word out so people would order that option in their 76's?  It didn't look like it was that great of a seller.  If they had not made it the only/standard engine in the Seville it probably would have been a very rare system.
Cadman-iac
 You could be right about that TJ. I keep thinking that my old bosses car was a 73 because I thought it had round headlights, but that was years before I got into Cadillacs.
 I do remember that he never drove it because it had issues with the injection system, and that was early 80's.
  Rick
CLC# 32373
In the early 70s they threw everything they had
into the system, including port injection, just
introduced integrated circuits, and an electronic
MAP. Hey its a Cadillac.
By the 80s models they had more parts suitable
for EFI, including OX feedback and the less than
a decade old micro processor.  Lots of cars could
meet emissions with new digitally programmed
spark advance, and a carb with electronic modulation.
Bruce Roe
