Trouble posting a response
Started by Ralph Messina CLC 4937, January 12, 2021, 06:45:05 PM
 Is anyone else having troule posting? I've tried posting a response several times and it never appears in the topic. Each time I try, i get a window saying I've already posted the replay........But it's no where to be seen.
2018 GMC Yukon
BlackCads
Hi Ralph
I will try to reply to your post (here goes).
I hope you and your family are well and are you (hopefully) embarking on another project?
Lexi
That has happened to me before. Usually it seems that the system is slow (busy?) and is still processing while you are wondering what happened to your reply. It might even say that you have replied but it seems that it is not there. Sometimes when you go back and look then poke around a bit more, your post suddenly appears. It might also happen if you attempt to attach an image that is too large. If you go back and scale down the image and re-do, that will work, (if that is the problem). Hope some of this helps.
Here is my test as I reply!!!
Clay/Lexi
Guys,
Thank you. Dopey me didn't realize the files were gigantic.
Hi Lucas, hope you are well. I no longer build cars to show.  I go to shows to see the cars.
Ralph
2018 GMC Yukon
Lexi
Have done so myself many times in the past, Ralph. CLC Forum Administrator Peter Gariepy noted how to post photos, in which he also stated what size limitations the system has. I quote Peter with the following:  (Clay/Lexi)
How To Post Photos:
Start a new topic, or respond to an existing topic.
Enter your subject text and body text as always.
Click "Attachments and other options" at the bottom of the body text.
Under "Attach" click the "Choose File" button.
Choose the photo you wish to attach from your computers file system. (Must be smaller than 2,000*2,000 pixels.)
Click "(more attachments)" if you want to add more photos.
Once you've added all the photos you want click "Post".
