Help removing window cranks from door cards, 41-60S
Started by Ohjai, January 19, 2021, 06:11:16 PM
Ohjai
I need help.  What tool or technique do I need to remove the window cranks and door handles from my 41 -60S?
Jim
'38 Cadillac Series 60 S
'41 Cadillac Series 60 S
2017 Cadillac CT6
'62 Buick Skyhawk Conv
'49 Bentley MK-VI  Sold
'53 Bentley R-Type  Sold
'66 Ford Thunderbird
'64 Rolls-Royce Silver Cloud III
'75 Rolls-Royce Silver Shad Sold
'78 Rolls-Royce Silver Shad II
'80 Rolls-Royce Silver Wraith II  Sold
'81 Rolls-Royce Camargue  Sold
'88 Rolls-Royce Corniche II
'89 Rolls-Royce Silver Spur
2020 Ford Escape
wheikkila
Hi Jim
On my 40 La Salle it used a c clip and I used my 60's door handle removal tool.
Thanks wayne
Ohjai
2017 Cadillac CT6
2020 Ford Escape
wheikkila
If it were me, I would buy the set from Harbor Freight.
rsms
in a pinch you can use a hack saw blade and catch the open end of the c-clip and pull it out of the handle.  Just use caution as you wouldn't want to nick your door panel.
Ohjai
It looks like the tool from Auto Zone does not work, the opening is much to wide to push the clip out, will go to Harbor Freight this afternoon.
Jim
2017 Cadillac CT6
2020 Ford Escape
harvey b
when you push the tool in,be careful the clip does not fly away,they are smaller then the later years GM products,They work the very same as a 60's gm car would,they take a delicate touch to pop out,but once you do one it is all easy.Big thing is to make sure the clip is in the way it is supposed to be,sometimes they are in backwards,will work either way?,you push down the eustachion plate and then insert the tool,it is between the plate and the handle,not between the plate and the door card?. Good Luck harveyb
Harvey Bowness
Ohjai
Went to Harbor Freight, spent $100.00 on STUFF, got there removal tool also.  It appears pone of the tools is a duplicate of the one from AutoZone.
Neither tool works.  the opening is too wide and the inner opening is too small.
Can someone measure the opening of the tool they use to pull these handles.  Once I have that dimension I can grind down one  of these tools.
Thank you
Jim
2017 Cadillac CT6
2020 Ford Escape
Ohjai
Well I got the handles off, used three different methods for the three handles, a very small drill bit and a hammer worked for one of them, a tiny screw driver for the second and I can't remember what worked for the third one.
I am going to make up a tool for the other doors and will post a picture of it here when I get it made,
Jim
2017 Cadillac CT6
2020 Ford Escape
