-51 convertible project
Started by dogbergs, February 13, 2021, 02:57:38 AM
dogbergs
Macabry, my spare wheel well was mint, believe it or not.
Thanks and keep up the good work you too!
/ Johan
-51 Cadillac serie 62 convertible, project
-64 Dodge Polara 2dHt, 1 driving and 1 for spares.
-70 Volvo 121 (Now sold after 21 years)
-63 Plymouth Max Wedge clone, project
-42 Harley WLA
-43 Royal Enfield WDCO
-33 Ford Pick up, project
dogbergs
#41
For some strange reason this has been over me like a dark cloud a couple of months, its just.. I really dont.. well I'm not comfortable going under there, fragile things connected with old cables and you better have some structure what you're tearing apart...
It was not dangerous at all! Came down nice and easy and most of the cables looking really good. I will go through them and do some minor repair and cleaning. Really nice to have it all revealed and easy to work with.
Added,
Will not do full dash resto with paint and chrome at this point. One of things I thought was really badly done to the -53 sedan was interior paint job, they just wiped out the cars history with a bad paint job, can't really forget this. So to make up for someone elses mistake in another car, I just don't this time. We give it some tender care and let the history remain.
Radio is sent away for professional love and care.
-42 Harley WLA
James Landi
I'm a great believer in tsking many cell phone pictures "lest I forget" where wires connect. Looks like great progress has been made.  I remain very respectful of your fine work.  James
dogbergs
Thank you James.
Yes, in my case maybe the most used function, for remembering and seeing things where you can't get your head.
/ Johan
-42 Harley WLA
dogbergs
Working a little on each side of the shop, prepping for sanding, primer/ filler on one side.
On the other side the first shy cut ever by my hand on this Swiss made Sip jig borer from 1958.
No, not the original 331, it's an 11 year younger brother with some improvements made along the years and some more power to give.
Still a Cadillac engine, still looking pretty the same.
-42 Harley WLA
dogbergs
Had to share one more just for the beauty of this machine.
-42 Harley WLA
dogbergs
#46
Gathering the pieces that will go in the first round, probably will eat the wallet inside out anyway.
All but 1 side glass were broken so we go for all new there, windshield arrived at the glass shop 2 weeks ago.
Lookin at Steele Rubber for rubber products, anyone has some input? Guess there can not be so many competitors?
-42 Harley WLA
dogbergs
#47
I guess the fender spears have been replaced sometime, seems to be stainless. Is -53 the first year of stainless spears?
And the most likely correct answer came from jmurrayent.
-51 was probably the transition year so you could get what there was.
-42 Harley WLA
dogbergs
Plan is primer/filler next week and hopefully some colour the week after that.
-42 Harley WLA
dogbergs
#49
I'm very happy to say that game plan was held all the way. 2 weeks of work and I'm quite satisfied with the result. I've never before painted a whole car but I guess this was a good first one, with all large body panels off. Now it's only the rest to come..
-42 Harley WLA
dogbergs
#50
Since this is a bit anarchistic resto, where anything that suits me is okay, as you already understood..
Found a bed liner that looked almost factory for my early B-body Mopars and since it was available and likeable, just went for it.
-42 Harley WLA
Eldovert
Johan,
The car looks 1000% better. Keep up the great work!
Cheers,Pat MacPhail
dogbergs
Thank you very much Pat, and cheers right back!
Best / Johan
-42 Harley WLA
dogbergs
#53
Little off topic but here I got lost to the Cadillac transition models between the 40's and 50's designs.
My old sedan, lives in Finland now. My son, before almost everything.
Suitable it's reply #53.
-42 Harley WLA
CadillacGlasses
Johan, This project is inspiring, and that color you're painting your car in is amazing, I'm really excited to see the rest of the panels when they're coated!
-Mike
M. Herbert
29645 - CLC West of Lake, CLCMRC Board Member
1949 Series 62 Conv. (in progress)
dogbergs
Thanks Mike, I'm really happy with the color too. will assemble some on the body before start painting the other parts but pretty excited myself, tell you that!.
/ Johan
-42 Harley WLA
dogbergs
#56
I will gladly, thankfully admit that I got some help rebuilding the old Hydra matic. Svante Eriksson, drag racing legend from the seventies with "Norrlandsjeepen" 1,2 and 3 all in different shapes, did the rebuild for me. He's a neighbor to my shop and a pro with transmissions, everything mechanical else too by the way. I used a bell from -55 and cut it some, to hopefully fit the short back 390 block and be able to reach the torus cover bolts, still waiting for the correct flywheel, so the -55 starter will fit. This is like everything else, -let's try and see if it works!.
Block is bored and honed ,030 over, washed a couple of times and ready, the thing holds me back now is thinking about balancing crank and flywheel together and still waiting for that flywheel to come sailing over the great ocean.
-42 Harley WLA
dogbergs
#57
Started some plumbing business yesterday, was hoping to use the old factory steel pipes for hydro lectric system, but no.. Too much rust and I've only seen the outside. Will use soft copper lines instead. Top control valve was quite stuck but came out ok, only had to replace solenoid springs.
Added,
Yes, the Bitumen business had to come first.
-42 Harley WLA
dogbergs
#58
This looks almost beyond..
Added;
It came apart without breaking anything, and thats a good sign.
But I should mention the bronze bearing came out with shaft and that created some hours..
Added II;
And it woked from dead, feelin lucky! I just recently saw what Caddy daddy asked for a repro.
Peace and TRUE democracy for the world.
Slava Ukraini.
-42 Harley WLA
dogbergs
#59
Took a pause on the Hydro-lectric and trying to find a place for all loose ends.
Doing some kind of bending test for which and where to replace, if it bends easy without breaking it stays.
It sure has been some electricians here before me.
-42 Harley WLA
