Replacing Motor Mounts on 69 Eldorado
Started by Loveofclassics78, March 29, 2021, 01:13:17 PM
Loveofclassics78
Good morning.  I've got my newly rebuilt motor mounts from Steele Rubber, ready to be put on.
I'm replacing the Front Mount and the two rear mounts on the back of the transmission.  Who's done this before?  Any thing to look out for?  This job seems pretty simple, I just wanted to prevent any hangups.
Don
G'day Don,
When replacing the front one, make sure that the fan does not strike the fan shroud as you raise the front of the engine to be able to slip the new one in.
If the old ones are so bad that they have collapsed, then you will need to raise the engine higher than it is now.
Might be a good idea to also loosen the Exhaust Manifold to Engine pipe nuts to enable everything to not get strained, then re-tighten them afterwards.
Loveofclassics78
Thanks for the response, Bruce! I appreciate the tips.
