Valve stem seals to 429?
Started by Matti R, May 28, 2021, 10:12:45 AM
Matti R
I am rebuilding 429 for 64 DeVille and got Felpro head gasket kit including valve stem seals. Is it recommended to install those even though they are not used originally? O-rings will be installed.
Best regards,
Matti
CLC #33333
67 DeVille convertible Sudan beige
79 Seville
64 Sedan DeVille
66 Calais Coupe
rajeevx7
I'm fairly certain my '66 429 has those oil shedders on the stems. They fit pretty tight over the cast valve guide pedestal (if I recall correctly).
So in yours you have o-rings sliding up and down inside the valve guide...or what?
Matti R
No, the o-rings are installed to a groove in stem close to the top. In my engine the rings were hard as a rock. They are standard, and there are no stem seals like in many other engines. I assume there is nothing wrong to install the stem seals as well. Need to check that it will not reduce the valve lift.
Best regards,
Matti
CLC #33333
79 Seville
64 Sedan DeVille
66 Calais Coupe
