1966 Cadillac deville coolant crossover manifold
Started by frank1966, June 14, 2021, 09:49:31 PM
frank1966
The coolant cross over manifold has like a nipple on the bottom that I inserted into the water pump ... the nipple is corroded and has partially broken off is this replacable or do i need the entire cross over header/pipe
Thanks Frank
dadscad
Years ago I had the nipple on my 63's crossover repaired because it was also corroded to the point of not sealing.  I took the crossover to a good machine shop. They turned down the nipple a little and pressed a brass bushing on it to bring it back to spec. I used 2 orings to make sure it sealed in the water pump.
Enjoy The Ride,
David Thomas CLC #14765
1963 Coupe deVille
Joe G 12138
Ditto on the 2 O Rings. I've done this many times and it really helps avoid leaks and makes installation more "forgiving" .  Joe Gibeault
Frank g
Hi guys
Nice name Frank .I'm starting to get a leak I beleive it's on the top of motor either oring or gasket ... I hope I don't have this nipple.issue ?? Any advice please thankyou
Bryan J Moran
CLC 35000 in number only
dn010
Only way to find out is to start taking things apart.
-----Dan Benedek
'81 DMC DeLorean
