‘60 NSS hissy fit
Started by David Greenburg, June 16, 2021, 07:26:28 PM
David Greenburg
The NSS on my '60 hisses at startup. The hissing subsides after 20-30 seconds, and the car does not exhibit any other vacuum issues; vacuum door locks work fine, as does the automatic brake release. I might not even notice that this is not normal, except that my '61 does not do it.  Is this the beginning of NSS failure, or is it ok to live with it?
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
savemy67
Hello David,
I love these sorts of conundrums.
Is there a correlation at start-up between fast idle and choke unloading,and the hiss?
At start-up (fast idle), I would suspect highest vacuum level.  Half a minute later, maybe a drop in RPM, and less vacuum.
I don't think the '60 NSS has a diaphragm (someone correct me if I am wrong), but maybe it is slightly out of alignment so that the internal passages are not spot-on.
Can you connect a vacuum gauge somewhere and observe the state of engine vacuum at start-up and shortly thereafter?
Respectfully submitted,
Christopher Winter
Christopher Winter
1967 Sedan DeVille hardtop
Quote from: savemy67 on June 16, 2021, 09:13:22 PM
....I don't think the '60 NSS has a diaphragm (someone correct me if I am wrong), but maybe it is slightly out of alignment so that the internal passages are not spot-on.....
The NSS has a sliding "valve" that simply moves sideways, covering and uncovering the vacuum port.
If they are leaking, then the surfaces are not completely smooth, and have lost their "slipicity".
cadillactim
David
Sounds like the vacuum valve is going bad. There are two rubber seals in that valve, and likely the lower seal is sticking open, thus the hissing sound. It finally seals all the way and the hissing stops. The problem will likely worsen until the hissing doesn't go away.
I've rebuilt many of these switches, and most of these valves leak after 50 years.
Tim Groves
David Greenburg
Thanks, guys.  That's what I was afraid of.
David Greenburg
