PLANNED SITE MAINTENANCE (RESCHEDULED) Please note that the forums will be unavailable on March 5th, starting at 09:00 EST This down time is expected to last between four and eight hours, but could be longer if any issues arise. The purpose of this maintenance is to install a user selectable Dark Mode theme. To keep the current Light Mode theme, no action is necessary.
55 radio knobs
Started by Dzeman, November 15, 2021, 02:40:53 PM
Dzeman
Hello quick question on the radio knobs on the 54 55 Cadillac can someone help me. In my parts box i have a wavy brass washer a spring and what looks like cup and have no idea where they go do they possibly go on the radio knob side with the vacuum switch?
Caddy Wizard
If I recall correctly, the wavy washer goes under the nut.  Then there is the cup, followed by the spring, and finally the knob.  The spring helps return the knob to the neutral position in the middle (for the knob that is pulled and pushed to lower and raise the vacuum powered antenna).
Art Gardner
Dzeman
Here are my parts. If the bigger cupped washer isn't part of the knob setup I wonder where it's from
Those cupped washers are used at the dash trim or side moldings.
Dzeman
Ah as soon as I read that my memory came back must be for the radio trim piece I also have off thanks so much.
