1955 Cadillac speedometer removal
Started by Cadillac Jack 82, January 10, 2022, 02:12:44 PM
Cadillac Jack 82
Okay so my speedometer has started making the dreaded buzzing noise and it jumps around when its cold.  Once the interior is warm it functions as it should.  I assume its time for a rebuild/repair.  I was looking at the back plate for the instrument panel and it looks as if the whole assembly is held in with one screw?  Is it possible to remove this unit without having to pull the cluster?
CLC Member #30850
1948 Buick Roadmaster 76S Sedanette
1959 Cadillac CDV
1966 Oldsmobile Toronado
Past Cars
1937 LaSalle Coupe
1940 Chevy Coupe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Super Panama
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1964 Cadillac SDV
1966 Mercury Montclair
1967 Buick Wildcat
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
signart
Art D. Woody
Cadillac Jack 82
CLC Member #30850
1959 Cadillac CDV
Past Cars
1937 LaSalle Coupe
1940 Chevy Coupe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1964 Cadillac SDV
1967 Buick Wildcat
1977 Lincoln MKV
signart
I recommend removing the cable and lubing that before removing the speedo assembly.  It must be removed from the back of the speedometer from under the dash. Cover upholstery, as withdrawal of the cable from the
cable housing can be like handling a grimy snake.
Art D. Woody
Jeff Rosansky CLC #28373
Yes, as Art says clean the cable. We ran some brake clean thru the cable housing and some pretty heavy gunk came out.
My skinny son was able to reach behind there and get the cable off without a problem. I just sat back and ate a donut while he did it..... Still not sure why I couldn't get back there myself.
Jeff R
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
signart
Speedometer cable issues, broken, splintered, stuck etc can result in damage to the speedometer. Best to attend to the maintenance of the cable before this happens.
Art D. Woody
Lexi
My good buddy Larry Blanchard showed me that the 1956 cluster has a lubrication point usually overlooked. Unfortunately this can only be seen with the cluster out of the car and the rear shell totally removed. Then visible and close to the speedo cable connection, is a tiny flat brass fitting that looks like a miniature freeze plug, (perhaps 1/4" in diameter if memory serves). Once pried out a drop or two (max) of oil is recommended. No mention of this in the shop manual Larry said, nor could I find a reference to it in the '56 Serviceman index. Not sure if the same on '55, but worth investigating. Clay/Lexi
Bob Kielar
The needle on my 55 was jumping around. I replaced the cable but that did not help. What I had to do was remove the gauge cluster gain access to the speedometer remove all the hardened grease clean and re lube the gears that was six years ago and has been working fine.
Keep Cruzin,
Bob Kielar
Keep Cruzin
1955 Cadillac Fleetwood
1956 Caddy
My 56 was jumping and making a terrible noise and I gave it a squirt of PB Blast and been working great for the last 3 months.
