1960 390 Cam To Crank Centerline Dimension Needed
Started by Blown Caddy, January 16, 2022, 05:08:56 PM
Blown Caddy
I am planning on making a cast aluminum timing cover similar to an old school "Moon Equipment". I need the dimension between the cam and crank. Their relationship to the cover bolts would be helpful also. I am new to the forum so if I make an error let me know.
Jon
