37-40 LaSalle rear axle gear ratios
Started by rg171352, July 20, 2022, 09:59:55 PM
rg171352
Did all of the rear ends found in 37-40 lasalles have the same gear ratios?  Were there any cadillac rear ends that would interchange with the LaSalle units that had different fear sets?
Thank you for your help!
Jay Friedman
According to my 1935-55 Master Part list, all 37-40 LaSalles had a rear axle gear ratio of 3.77:1.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
Bob Hoffmann CLC#96
Jay,
 Sorry, but you are incorrect. They came with 3,92 rear ends. Replacement rear ends made in 41 did have 3.77 rear ends. They are rare birds.
 Bob
Jay Friedman
Bob,
Since my parts book was published in 1955, I guess by that time Cadillac was only supplying replacement 3.77 rear ends.
Jay
Decatur, Georgia
jackworstell
Our 1937  Seies 60...which I would think would be about the same as the series 40
came with a 3.69 ratio, Terrible on a modern highway
We switched "pigs" to a 3.07 out of an early 1950s Cadillac
( optional with the Hydramatic }
Had to switch axles to 1940s Cadillac ( used for maybe 10 years )
This to match splines of the axle with that of the 3.07 pig.
Axles had to be shortened ...about 1 1/2" each
A bit of a project...but the car nows travels at 65mph just fine
Jack Worstell
jackworstell
...the 3.07 pig was a snug fit...had to do a touch of grinding
on the differential housing....but it slipped in OK
Jack Worstell
Bob Hoffmann CLC#96
Jack,
 Don't you fid that the 3:07 is a little tall when starting out??
 Bob
rg171352
Thank you all for your replies.  How would I be able to determine what gear ratio I have?  Where would I potentially find a 3.77 rear if I wanted to go that route?
LaSalle5019
#8
Just a comment....my 1939 LaSalle with the 3.92:1 rear axle ratio will run all day at 65 mph. The engine is turning just shy of 2700 rpm. I'll take it down the rural highways around me at 70 mph occasionally but at those speeds I would be more concerned about investing in tires (like Diamondback Auburn radials), brakes, steering, suspension, good driveline balance, etc.
Brad Ipsen CLC #737
Keep in mind also that a 39/40 with a 3.92 is about the same as a 41 with a 3.77.  15 inch wheels in the 41 and 16 inch in the 39/40.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
jackworstell
Bob Hoffman
Bob...no it turned out OK ,   We were concerned about that but
in the end we find the 3.07 OK
WE did replace the heads with 1940s heads so we have higher compression
ratio.  And we switched the distributor to one with vacuum advance
( also 1940s version)
So the end result is maybe 150hp instead of the original
135hp.  This helped offset any "sluggishness"  due
to switch from 3,69 to 3.07
Jack Worstell
