HT4100 1984 Seville Operating Temperature Range
Started by fellenzer, September 21, 2022, 09:16:47 PM
fellenzer
What is the typical operating temperature range of the '84 HT4100?
Michael Fellenzer, #30007
Indianapolis, IN
1976 Eldorado Convertible
1976 Fleetwood Sixty Special Brougham (EFI, ACRS)
1976 Coupe deVille (Astro/Cabriolet)
1984 Seville
1989 Fleetwood Coupe
1989 Sedan deVille
1992 Fleetwood
1992 Coupe deVille
1992 Sedan deVille
1993 Sixty Special (Ultra)
1994 Fleetwood Brougham
2015 SRX
smokuspollutus
I'm fairly sure they used 195 degree stat so ideally you should see temps hanging right around 200.
This is an engine you don't what to get hot.  Lots of stories back in the day where 'the temp light came on and I made it to (home - work - the service station)' and the next line was got a new engine or new car.
That is pretty much true for most engines by the 90's.   70's and older all cast iron engines could usually take getting good an hot a couple times without serious damage but when they started with aluminum and mixing metals getting them really hot more often then not leads to significant damage. Another way Cadillac was ahead of their time I guess.
