1969 Cadillac trunk lock linkage
Started by GBrown #8092, November 11, 2022, 05:55:26 PM
GBrown #8092
Is anyone parting a 69 (or 70) RWD Cadillac?
I need the linkage that goes between the trunk lock and the trunk latch. I damaged mine drilling out the lock. I decided it wasn't worth the $150 the locksmith wanted to do it. That turned out to be a short sighted decision.
Its not the usual simple flat piece of metal but an articulated linkage with a little balll joint in the middle.
Thanx
Glenn
M. Bankes
Hi,
I'm sure I remember seeing on of those here I could get out for you
Michael
