56 Vicodec
Started by JungleCadd, February 03, 2023, 02:04:30 PM
JungleCadd
Greetings Cadaholics,
Can anyone tell me how the Vicodec top is anchored at the windshield? Pulling off my flipper and molding it appears to be clamped along the pinch weld. If that is the case for the front and back then you would have to remove the windshield gasket to clamp it. It did nit see any remnants of any kind of closing channel or vicodec around the windshield like I did on the sides.
Cheers,
E
56 Eldo Seville
V63
It's been years since I put one of those tops on (1956 Seville) but it would be pinched under the window trim front and rear
JungleCadd
Quote from: V63 on February 03, 2023, 02:25:24 PMIt's been years since I put one of those tops on (1956 Seville) but it would be pinched under the window trim front and rear
oh ok. Thanks a lot! Good to hear it 1st hand. So its over the gasket and tucked inder the trim yikes. The trim is only held in place by the gaslet tho. Im any case i can land my new windsheild before i make up my mind about the vicodec top.
Cheers
E
56 Eldo Seville
