1940/41 62 series convertible coupe front seat question
Started by k8096, July 17, 2023, 10:10:39 PM
k8096
Is the front seat ( both cushions and surrounding structure) for a 1940/41 62 series convertible coupe the same as for a 62 series coupe?   I think the answer would be yes, but can someone confirm?   Both would have a split backrest that folds forward in order to gain access to the rear seat, and the dimensions should be the same.   Thank you.
J Gehring
Warren Rauch #4286
I can't tell for sure,but think the answer is no.
  From 1940 Cadillac body book
    Group 4B.0040 Spring,front seat cushion
    4108354 40-6227C (cushion 40 62 series coupe)
    4106141 40-5227C,67,40-6267 (cushion, late 40Lasalle coupe/conv,40-62 series conv
  Group 4B.0100 Spring,Front seat back rest
    4105531 right
    4105532 left  40-5227C,67,40-6267
    4108403 right
    4108404 left  40-6227C
From 1948 Cadillac body Book
    Group 34.0040Spring,Front seat cushion
    4122461  41-6127,6227 (41 coupe std upholstery)
    4122439  41-6127D,6227D (41 coupe deluxe upholstery-better springs)
    no listing for conv.
  Group 34.0100 spring,front seat back rest
    listing is for coupe only,std and deluxe upholstery.
I don't have any body books between these two.
Just because the springs vary does not prove the frame isn't the same.
I could not find a listing,for it(Fisher special order?)
  Warren
Brad Ipsen CLC #737
For a 40 Cadillac 6267 it certainly works to use a 40 LaSalle coupe seat.  There are no observable differences in the core structure. Upholstery is different. I had a very rusty Cadillac seat to compare it to and used a 40 LaSalle coupe seat in the car.  40 and 41 are not the same from what I know.  The 40 seats have much more wood structure. if convertible is typical to other models' seats are different and the mounting track is different. I have not done a 41 convertible so can't say for sure but in general 41 seats are quite different from 40.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
k8096
Interesting.   It's a '41 conv I'm working on.  I figured since the body was the same as '40 the front seat assembly would be the same too.  That's why I asked my question the way I did.
J Gehring
Poncholover
I need a front seat for a '39-40 B Body 2 door. All GM B bodies 2D will interchange.
If a '41+ would physically fit, this would be a game changer but I believe that those cars got a little wider?
Flattie Caddy
Brad Ipsen CLC #737
The changes from 40 to 41 are one of those very interesting Cadillac design stories.  Out comes a brand new body in 1940 and in 41 they make many changes in little things like door latches and big things like the frame that sits under the body.  Must prove that the engineers were in charge at the time instead of the accounting department. One thing on the convertible body the top frame is almost identical between 40 and 41.  Just one little small change.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
