Fuel pump 55 Cadillac
Started by Bob Kielar, September 07, 2023, 04:54:23 PM
Bob Kielar
Been looking all over the internet for a A/C fuel pump for my 55. There is a wide range of prices. Has anyone bought one recently and where to get one plus I would like to get a rebuild kit so I have a spare?
Bob Kielar
Keep Cruzin
1955 Cadillac Fleetwood
James Landi
Hi Bob,
While I've not owned a mid-50's SDV (since  1975), I can give you a couple of concerns that I learned the hard way based on frustrating experiences.   These "upper mounted" fuel pumps suffer from lack of lubrication inside the mechanical casing.  Old timers, back in the day, used to fill the casing with grease in order to keep the pivot arm from developing out-of- round lash that gradually affects the pump's ability to create suction-- since the cam follower only provides a limited push, there's little tolerance for wear in the pump actuator mechanism. Also, because the pump is mounted so high, any pin hole, even ones that don't drip or are located behind the pipe straps on the chassis or ones located on top of or inside side of the tank, defeat the pump's ability to suck gas.  Some folks have used electric pumps, but they MUST be of the correct pressure and electrically wired properly.  Hope this helps,   James
David King (kz78hy)
I have had Then & Now Automotive rebuild my fuel pump.  They also sell kits.  Great shop, turned my 55 pump around in less than a week.
https://www.then-now-auto.com/product/cadillac-fuel-pump-kit-fpa-221-1954-1956/
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
Bob Kielar
Thanks David I called them and their voicemail said they're closed for a couple of weeks will try later in September.
Bob
Keep Cruzin
Jay Friedman
A good fuel pump rebuilder is Arthur Gould.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
Michael Petti
I second Arthur Gould. He did the one on my 60 2 years ago and no problems at all. I had an original A/C to rebuild.
Bob Kielar
Thanks guys I'll try to contact Arthur Gould.
Bob
Keep Cruzin
