1957 Brougham questions
Started by Doremonger, September 08, 2023, 10:43:00 PM
Doremonger
Has anyone tried using a modern power seat motor unit with the original control switches and memory seat switch? If so, what may work?
Also, has anyone found someone who is doing reproduction turbine wheels in larger sizes? Trying to put in some larger disk brakes.
Thanks in advance.
V63
I put a 1971 seat 'trolly' under the brougham seat. Saved a buch of weight there. The memory seat portion worked perfect, it remembered exactly the position it failed in 1958 😖. I looked inside the brain box and ultimately determined it had Alzheimer's. I put the 1971 seat switch under the seat so as to appear original
David King (kz78hy)
I have some seat motors and 2 seat frames.
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
Doremonger
David King - modern seat motors or original? Going the restomod route on this one.
David King (kz78hy)
My parts are the OE ones.  Nothing newer, sorry.
David King
CLC 22014  (life)
1955 Eldorado #277
2012 Volt
