1961 Rear Speaker Details
Started by Clewisiii, November 17, 2023, 02:25:16 PM
Clewisiii
What was the OHM and size of the 1961 Rear Speaker.
The master parts book says the rear speaker is same from 47-62 then changes from 63 on.
Neither the parts book or service manual actually say what the speaker size is.
I hope you say 6x9 10 OHM.  But I think it is 8 OHM. And one place said it was a 5x7.
Cadillac Jack 82
8 is the minimum in order for you not to fry your radio.  They repop the speakers if you need one.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Cadillac Jack 82
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
klinebau
#3
The older speakers and head unit used a common ground.  I don't know all the ins and outs, but I don't think you can just use a modern speaker that matches the ohm rating.  I am sure someone here will post more details about what is and isn't possible.
EDIT:  After a little research, I think the issue is that you cannot used a modern radio with a common ground, so maybe speakers are ok.
Detroit, MI
