Intake manifold gaskets the same for 331 and 429?
Started by Julien Abrahams, November 22, 2023, 06:12:55 AM
Julien Abrahams
On my '54 series 62 I have an exhaust leak and I am guessing it is on the intake crossover (as I cannot feel any feal around the exhaust manifold, although it is hard to see).
Are the intake manifold gaskets the same for a 331 and a 429? Will it fit?
On pictures it looks the same, but there are no dimensions mentioned so hard to tell.
1951 Buick Eight special
1954 Cadillac series 62
1969 Austin Healey Sprite
1979 Opel Kadett
I don't know that era specifically but here is the listing from Rock Auto for a 63. It is strange that you can see it listed as fitting when you look up later cars but it doesn't list them if you look at the older cars.  Generally computers catch that sort of thing.
Is the odd year spread just due to when those models were available?
FEL-PRO MS8931SH1
CADILLAC    CALAIS                      1965-1967
CADILLAC    COMMERCIAL CHASSIS      1949-1967
CADILLAC    DEVILLE                      1957-1967
CADILLAC    ELDORADO              1957-1967
CADILLAC    FLEETWOOD              1965-1967
CADILLAC    SERIES 60 FLEETWOOD      1950-1964
CADILLAC    SERIES 60 SPECIAL FLEETWOOD    1949
CADILLAC    SERIES 61              1949-1951
CADILLAC    SERIES 62              1949-1964
CADILLAC    SERIES 70 ELDORADO            1958
CADILLAC    SERIES 75 FLEETWOOD      1949-1964
Julien Abrahams
Well,
I still have a pair in stock which are fine. As I was browsing on Rockauto to order parts for the '66 Eldordao zI am working on, I figured I'd check for intake manifold gaskets for the '54 as well (as I have a strong suspicion that there is an exhaust leak at the crossover on the intake manifold). It seemed odd to me as well, but it appears that the same manifold gaskets can be used for the 331, the 365, 390 and the 429. I guess that they changed the lay out in '68 with the 472. And I think you are right mr. Hopland. The period basically spans 1949 to 1967.
1979 Opel Kadett
From the parts book, there is a great variety and different part numbers (10!). If you rely on Rockauto to determine if parts are the same, you'll get trouble!
64\/54Cadillacking
Yes they are the same. It's strange how Cadillac would advertise in some of their literature that they improved the intake flow of the engine to increase horsepower, when yet the intake manifolds for our cars are pretty much the same from 1949-66? So how was their argument justified?
I think I could use the intake manifold from my '64 Cad, and use it on my '54. They look identical. It's also pretty crazy how much power Cadillac was able to crank out with such a small intake manifold compared to other big block engines of the day which had far larger manifolds. Even compared to modern V8's, these old Cadillac intake manifolds seem tiny.
Currently Rides:
1964 Sedan Deville
Previous Rides:
1987 Brougham D' Elegance
1994 Fleetwood Bro
1972 Sedan Deville
1968 Coupe Deville
1961 Lincoln Continental
Quote from: Roger Zimmermann on November 24, 2023, 03:24:49 AMFrom the parts book, there is a great variety and different part numbers (10!)
Interesting.  Those numbers are for just the 2 gaskets or are those for some sort of set?  If its a set I could see other parts of the set being different.  Materials maybe?
I would assume we would not be surprised if it was 49-62 and 63-67 since that was the family split.  I suppose its really based on the bore spacing.  Guess they were thinking big early if they didn't have to increase it in the 60's when things were growing.
Oups! Forget what I wrote, wrong line (intake manifold)...Effectively, the parts book say that from 1949 to 1967 the intake manifold gaskets are the same, part # 1453393, group 3.270.
Julien Abrahams
Thanks guys. Then I do not have to order new ones :).
1979 Opel Kadett
