1959 Cadillac battery issue
Started by Cadillac Jack 82, December 07, 2023, 02:35:30 PM
JayRudig390
I used this battery as well and it crapped out after a year and a half
gkhashem
Quote from: Cadillac Jack 82 on January 02, 2024, 02:04:22 PMSo far so good.  I think I just had a defective battery.  She's not had an issue since I switched out the battery.  I'd eventually like to get a repro one but that can wait.
You know I love it when all the experts chime in. Like I said above check the battery first. I have had a few that only lasted a few weeks and when tested were gonzo. I am talking any brand.
If the car was starting fine and one day you needed to replace the battery (that was old) and then the problems crop up why start with the tough solutions first?
I get it if you have gone through 2 or 3 batteries in a short time.
While it could be another issue, testing the battery is easy. So eliminate easy first, use some logic. Too much of a coincidence for a new problem to crop up.
1970 GMC C1500
1992 Oldsmobile 98 (OCA 1st)
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
1966 Coupe Deville (Sr #861)*
Cadillac Jack 82
I agree however it was just easier for me to swap the battery out at the time since I wanted to enjoy the car and not spend an afternoon tracking down gremlins.  Since changing the battery she's always started with a flick of the key and has ran well with all the options running (lights, radio, etc).  Batteries are only 180 here so it wasn't too bad.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
gkhashem
Quote from: Cadillac Jack 82 on January 10, 2024, 11:58:53 AMI agree however it was just easier for me to swap the battery out at the time since I wanted to enjoy the car and not spend an afternoon tracking down gremlins.  Since changing the battery she's always started with a flick of the key and has ran well with all the options running (lights, radio, etc).  Batteries are only 180 here so it wasn't too bad.
You actually did test the battery, dropped another one in and no problems. Conclusion the battery was no good.
Hope you got some money back for the battery warranty.
1970 GMC C1500
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
Cadillac Jack 82
The battery was purchased by the previous owner and in Pittsburgh.  It was at no cost to me so getting another battery was no skin off of my teeth.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Gabe Davis
Quote from: Jon S on December 24, 2023, 04:08:04 PMYou have a Ford battery in your car. You should have a Group 27; NOT 27F.
What's the difference between the Ford electrons and the GM electrons? ;)
1959 Coupe DeVille
Rosewood with Dover White Top
Cadman-iac
 The difference between them is that Ford has the positive and negative posts on opposite sides.
 Other than that, they are identical.
 Rick
CLC# 32373
Gabe Davis
Quote from: Cadman-iac on January 12, 2024, 10:59:50 PMThe difference between them is that Ford has the positive and negative posts on opposite sides.
So that would effectively move the posts to the forward side of the battery as you would have to spin it around to match the polarity?
1959 Coupe DeVille
Cadman-iac
  Yes, that's really the only difference.
 The terminals are moved to the rear, or opposite side of the battery.
CLC# 32373
Cadillac Jack 82
Whats everyone's consensus on the repro batteries?  Love to get some for both Cadillacs and the Olds.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Jon S
 Rick
Exactly
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
