Fuel Grade Recommendation for '67 DeVille
Started by CadConvert67, February 22, 2024, 09:16:24 PM
CadConvert67
While this topic may have been covered previously, my question is what grade fuel is recommended for running in the 429 in my '67 DeVille convertible?  Local options include 91 recreational gas but if on the road may not be available.  Thanks for any direction.
64\/54Cadillacking
The 429, as well as other Cadillac engines from this era require premium fuel as they are high compression engines. 91 is barely adequate for these motors since when these cars were new, they required at least 100+ octane ratings in order to run very smooth at original timing specs.
I've never tried using 87 since I don't want to risk pre-detonation in my 64 Cad.
Currently Rides:
1964 Sedan Deville
Previous Rides:
1987 Brougham D' Elegance
1994 Fleetwood Bro
1972 Sedan Deville
1968 Coupe Deville
1961 Lincoln Continental
V63
As a frequent and gratuitous participant of the forum here, now labeled a "moocher" ...please consider the source:
I notice that Lucas fuel additive reports their product is also an anti pinging formula. As well as upper cylinder top lubricant. I just paid $35 for a gallon and treats 10 gallons with 3 oz.
I'll try it! Will advise!
Cadillac Jack 82
We only get 91 here in AZ.  Lead additive plus that works fine but I wish I could get my hands on avgas
CLC Member #30850
1948 Buick Roadmaster 76S Sedanette
1959 Cadillac CDV
1966 Oldsmobile Toronado
Past Cars
1937 LaSalle Coupe
1940 Chevy Coupe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Super Panama
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1964 Cadillac SDV
1966 Mercury Montclair
1967 Buick Wildcat
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
Quote from: CadConvert67 on February 22, 2024, 09:16:24 PMLocal options include 91 recreational gas but if on the road may not be available
Most places the premium option with the note on it is non ethanol which is a good thing for an old car especially if it doesn't get used a lot.  The definition of recreational usually includes classic cars too.
If the pump says 'off road' is when you have a problem because 'off road' fuel doesn't have the road taxes on it.  Diesel is often sold that way but I don't think I have ever heard of gas except in the case of aviation gas.
badpoints
CadConvert67
Thank you for the feedback and recommendations!
CadConvert67
One reply addressed the "on the road" comment in my question.  To clarify, locally I have the option of buying 91 rec gas which has no ethanol but when I'm away from my home area, that may not be an option.  Thanks to all who addressed my question.
Gabe Davis
Quote from: CadConvert67 on February 25, 2024, 09:14:30 AMI have the option of buying 91 rec gas which has no ethanol but when I'm away from my home area, that may not be an option.
Check out the Pure Gas app. It shows you the location of gas stations with ethanol free gas in your current location or anywhere on a map. I found a gas station near my house that I never would have thought they'd had ethanol free 91.
https://apps.apple.com/us/app/pure-gas/id454559068
Then throw a little VP Madditive in there. I use the "off-road" version in my '59 as it has TEL in it.
https://vpracingfuels.com/product/octane-booster-vp-octanium/?c=367&;
It made a massive difference in how smooth the idle is on my car. And helps keep the valve seats happy.
1959 Coupe DeVille
Rosewood with Dover White Top
Jeff Rosansky CLC #28373
I run standard mid- grade with a little Marvel's. She does just fine.
Jeff R
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Clewisiii
Tried looking into the Pure Gas app. I cannot download it because it is for an older version of Android
jaxops
Quote from: Cadillac Jack 82 on February 22, 2024, 11:00:23 PMWe only get 91 here in AZ.  Lead additive plus that works fine but I wish I could get my hands on avgas
Don't use AVGAS!!  Just my opinion but adding Seafoam for the ethanol, and an octane booster is probably your best bet.
1979 Lincoln Continental
Jeff Rose
CLC #28373
One reason would be the lack of road tax. I believe most states its $1000 minimum fine or $10 per gallon which ever is greater.  I don't think there are typically swat teams in the bushes around airports looking for this but its still something to consider.
Its also a hassle since in most cases you can't just drive up and swipe your card.  Then the cost, right now in the USA looks like its about $6.50 average vs $3.30 for regular and what $4.50 for non ethanol premium?
Aside from the legal issues, AV Gas is going to UL 94. There are other characteristics that detract from it's being appropriate for automotive use such as lower vapor pressure, etc.   guess we are fortunate here in Texas (and many other states) that we have 93 octane pumps. I ran that for 20 years in my 66 (10.7:1 CR) and fro just going to the track or drive in it works well for my "hot rod" 73.
