PLANNED SITE MAINTENANCE (RESCHEDULED) Please note that the forums will be unavailable on March 5th, starting at 09:00 EST This down time is expected to last between four and eight hours, but could be longer if any issues arise. The purpose of this maintenance is to install a user selectable Dark Mode theme. To keep the current Light Mode theme, no action is necessary.
1960 exhaust manifold
Started by 60eldo, May 17, 2024, 09:15:34 PM
60eldo
 Got my engine back today. Very excited. Exhaust manifolds are not on the engine. Should I use gaskets or not. Ive never seen gaskets on them.
Jon. Kluczynski
Clewisiii
I would say yes. I scraped gaskets off of my 61 when I disassembled it.
I also used high heat gasket sealant with the gaskets.
The only time Gaskets should not be used is when the parts are brand new, or after machining.
The Gaskets are supplied in the gits to allow for the imperfections and unevenness of old and worn parts.
Exhaust Manifolds are designed to slip and slide as they go through the heating and cooling cycles, which is why they have at least one hole that is the same size as the retaining bolts, (for locating) and the rest are larger, to allow the slippage.
Another reason why the heads of Manifold Bolts has a flat washer instead of a spring washer.
Cadillac Jack 82
Yes to gaskets unless you want it to sound like a 1920s tractor
CLC Member #30850
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
60eldo
       BTW Im trying to install the engine with the motor mounts on, but the studs on them are getting in the way. May half to take them off, and install them after the engine mounts, to the trans
Jon. Kluczynski
