Hydramatic question
Started by jwwseville60, May 22, 2024, 07:14:00 PM
jwwseville60
On my 1963 sedan, the trans hunts back and forth between 1-2 gears on a steep incline with gentle moderate throttle. Give it more gas and it smacks into first.
Is this normal or a sign that it needs a rebuild?
Thanks!
Lifetime CLC
Cadillac Jack 82
TV rod adjusted right?
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1964 Cadillac SDV
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
It could be that the front unit coupling (responsible for second and 4th gear) is leaking. Not enough that the transmission will do only 1-3 when warm but just enough to be unstable.
Anyway, hard to do a diagnostic from the other side of the ocean!
Big Fins
Not doubting you, but are sure it's a 1-2 hunt and not a 2-3? First even at wide open throttle is only good for 25mph at best. It just gets the 5000 pound beast moving.
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
Eric DeVirgilis CLC# 8621
I don't know if it's possible to remain in first gear beyond 5-10 MPH no matter what you do. There's no direct way to hold the car in first with the lever setting; "L" position only limits the transmission to first and second.
Quote from: Eric DeVirgilis CLC# 8621 on May 23, 2024, 10:56:05 AMI don't know if it's possible to remain in first gear beyond 5-10 MPH no matter what you do. There's no direct way to hold the car in first with the lever setting; "L" position only limits the transmission to first and second.
It's possible, but only when something is going wrong: the weight on the governor from my '56 de Ville went off during the drive: I had only first and reverse...Fortunately, I was as 1/2 mile from my garage!
