Fillers between body and bumpers
Started by Roger Zimmermann, August 27, 2024, 04:49:34 AM
I should supply for a 1979 Eldorado a rear filler kit between bumper and body. There was once a supplier named Sandkindustries, but it seems that this company is no more a supplier for those parts. The sole delaer I found with fiberglass fillers is Caddy Daddy.
There was once somebody offering flexible fillers but I forgot his name.
Are there other alternatives for those parts?
Mike Josephic CLC #3877
Hello Roger:
The original flexible fillers were made from a polyurethane
compound.  To my knowledge, these have not been offered for years now.  All of the replacements now available are made
from ABS plastic,fiberglass,or similar rigid material.
When I replaced the fillers on my 1973 Eldorado (that was 20
years ago) I used a mix of original (NOS) fillers and ABS
plastic. Once they are on the car, the difference is not
noticeable.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Eric DeVirgilis CLC# 8621
Last year I ordered the so-called soft plastic fillers from Cadillac King (or Kingdom?) for a 1977 DeVille, but they weren't all that pliable. However, they were far better to work with and fit perfectly. The fiberglass items fit terribly and needed a lot of grinding/shaping to get them to work. The paint on the fiberglass parts came out nowhere near as well.
Putting their kids through college, one Cadillac at a time.  ;D
Thanks for the comments. Even if the kit is about $ 50.00 more expensive than the fiberglass one, I ordered on eBay an ABS kit.
billyoung
How things have changed. When I was younger you would go to a junk yard and pull a part and the guy would say, give me 5 bucks. now you go online and see, screw that holds on a door handle $ 4,258.63.
Age 69, Living in Gods waiting room ( Florida ) Owned over 40 Old Cadillac's from 1955's to 1990 Brougham's. Currently own a 1968 Cadillac DeVille Convertible and a 1992 Cadillac 5.7 Brougham.
