1969 DeVille Water Temp Light Dimly Lit
Started by R Simone, September 13, 2024, 11:17:57 AM
R Simone
Rebuilt the original 472 over the Winter/Spring and have had it out on the road less than 1000 miles doing some fine tuning etc.  She is running smoooooth and strong and have mostly had it out on nice cooler late Summer days.  The last couple times I got home just after dark and noticed my "Water Temp" light every so slightly lit. I couldn't see it during the day it was so dim, but it's not on at start up in the garage so I'm not sure how long it's taking to come on.
Along with the complete rebuild I've:
*Double checked timing and its EXACTLY 5 degrees before TDC
*All cooling components were rebuilt or new (Water Pump, Fan Clutch, Radiator, Hoses, Heater Core...)
*New 180 Degree "Fail Safe" T-Stat
*New Cooling Temp Sender
It doesn't "Seem" hot and I wasn't idling around town in hot weather when it happened either. That light lit up brightly at break in when timing was off and she got a little hot.  The plugs look a little bit lean, but she's running so good.  I don't have a temp gauge currently, but man everything is new.  Why would it light up just dimly - Anybody seen this before/have ideas?
Disclaimer: The one thing I know is wrong is that I haven't installed the small braided ground from the P/S Head to firewall as I couldn't locate/think the spade broke off.  I know a bad ground can cause weird things with lights, but would think it has plenty of other grounds without this.
Lexi
Might want to test your rad's pressure cap, or if no acess to a tester-just replace it. With a tester you could also pressure test the entire system and look for coolant leaks. Clay/Lexi
Sounds like you MIGHT have the wrong sensor. I assume we are talking about the sensor that sits in tec drone center under the AC compressor
Most likely its a bad or wrong sender but you want to be sure so pick yourself up one of those IR temp guns, they are cheap and easy to find these days and even the cheap ones seem to be reasonably accurate.  With the gun you can verify that you are not actually hot enough that the light should be coming on.
If you have an AC compressor in place you won't likely be able to read the sender but its in the same passage that goes over by the base of the distributor so you should be able to get a good reading there.
R Simone
Radiator Cap is new and not a drop of coolant leaking anywhere.
Yep it's the coolant temp sender under the AC Compressor. It's a "Standard Motor Products TS6" that Rock Auto listed as the replacement part.
My buddy has a temp gun so I'll try testing in that area next time I have it out.
Try putting another at least temporary ground on it and see what that does.
A SMP TS-6 is the sensor for the temperature gage. The sensor you need for the  warning light  is different. I will look tomorrow for the part number.
James Landi
You did a ton of motor work and cooling system work--- use that laser thermometer (if it's a good one... most of the cheap ones are less than worthless junk).   Install a temp gauge in your engine compartment.  NEVER trust the idiot lights...(cautionary tale) on a hot sunny day on route 95 in Florida following a complete engine and cooling system rebuild, I couldn't see the idiot light "glowing"--- radiator blew out and engine head gasket failed. While taking out the blown radiator,we discovered a bunch of gunk blocking the radiator passages-- coolant  couldn't pass through the radiator--- so consider a serious back flush and an installation of a cooling system filter.All good insurance for an old engine that could have a pile of accumulated muck in the engine's water jacket.
R Simone
My understanding is the water temp sender is under the AC compressor is for the water temp light and the sensor at the left rear (D/S) of the block is the thermonuclear meltdown engine temp light. The engine was taken down to the bare block and flushed Etc so I'm confident everything is clean.  Hopefully either insufficient ground or a bad sender. I did see a negative review on that sender about erroneous readings, I'll have to see if my service manual shows what the "Water Temp" on-temp should be. The extra ground is an easy first check so I'll try that next time.
Big Fins
Greg seems to have a list of the correct sending unit parts. He's already told you the one you replaced is for a gauge unit. PM/Email/Call if you know him well enough. He said he would post the correct part number tomorrow, yesterday and we still have 12 hours left, give or take.
It's too damned hot in Texas to be in a hurry right now.
You are aware I'm semi-joking here, right?
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
Finally found one of the new sensors I knew I had but were hiding from me. Here is the part number and a couple of pictures
By the way, the true function of this sensor/light system is "low coolant" indication. When the coolant drops below the level of the sensor, at say 220 degrees F which is within the normal range, steam at radiator cap pressure begins to form and becomes super-heated above the temperature of the water below it. When the temperature of the steam reaches 260 degrees F, the sensor trips and grounds the circuit lighting the light.
R Simone
Quote from: Cadillac Kid on September 14, 2024, 12:41:56 AMA SMP TS-6 is the sensor for the temperature gage. The sensor you need for the  warning light  is different. I will look tomorrow for the part number.
Ok, NOW I understand what you're saying.  I didn't realize there was a difference and when I ordered and thought "Heck the one that's .55 more must be the better one, I'll buy that" - I completely overlooked "With Gauge"
Serves me right for being a spendthrift. I'll get this changed out this week and report back.  Thanks!!!
cadillacmike68
Quote from: "Cadillac Kid" Greg Surfas 15364 on September 14, 2024, 12:41:56 AMA SMP TS-6 is the sensor for the temperature gage. The sensor you need for the  warning light  is different. I will look tomorrow for the part number.
1969s do not have a temp gauge. The last year for the gauge was 1968. They had to make room in the dash for the left and right arrows, so away wen the temp gauge.
The 1969s and later had the coolant overflow recovery tank, making coolant loss a lot less of a problem.
"Cadillac" Mike
R Simone
In case anyone needs one the correct style coolant temperature switches are available through Cad Company (Part# WS21101).  I replaced mine thinking I'd put the problem behind me, but noticed very faintly the temp light on during a night cruise (You definitely can't see it during the day). I still thought maybe it was just something funky with the dash light or grounds, but driving back from the lake a few weeks ago (about an hour at highway speeds) she ran flawlessly, then when I got off the highway at a light she just died and cranked extremely slow upon restart which I didn't think was going to happen. She then suddenly fired up but it worried me - once this heat wave dies down I will recheck the timing, but man she is running so smooth I just can't see it being timing...
Have you been able to verify what temps you are actually running?   If you are running hot for some reason there are a few options for why it could stall and the slow cranking.   But you could also have other issues that are not directly related that just happen to be happening at the same time.
James Landi
#16
I suspect that you ignored my post from last September. The accumulation of rust and gunk IN THE COOLING passages and engine's water jackets is a slow moving time bomb for your rebuilt engine. Over 5 decades, This material clogs radiator passages and well as the head gasket and causes the engine to overheat in critical areas.
 Use a laser thermometer (if it's a good one... most of the cheap ones are less than worthless junk).   Install a temp gauge in your engine compartment.  NEVER trust the idiot lights...(cautionary tale) on a hot sunny day on route 95 in Florida following a complete engine and cooling system rebuild, I couldn't see the idiot light "glowing"--- radiator blew out and engine head gasket failed. While taking out the blown radiator,we discovered a bunch of gunk blocking the NEW radiator passages-- coolant  couldn't pass through the radiator--- so consider a serious back flush and an installation of a cooling system filter.All good insurance for an old engine that could have a pile of accumulated muck in the engine's water jacket.
Lexi
Good advice. I installed a mechanical temperature gage in my Cadillac, and wired it to my headlight switch so the dial is lit when the lights are turned on. I always want to know what is going on inside my engine when out on the road. Clay/Lexi
