Hot starting trouble in my 39 Lasalle
Started by bariman, October 28, 2024, 09:09:56 PM
Quote from: Sloriter on December 25, 2024, 02:46:58 AMThis is particularly a problem for the '55 which is only 6 volts to begin with.
6 V on a 1955 Cadillac? From 1953, a 12 V system is standard.
 ;D   Do believe was referring to his '55 T-Bird, which were/are indeed 6 volt.
Oliver Betker
Quote from: Barry M Wheeler #2189 on November 03, 2024, 06:50:25 PMFirst, get a double ended woven (if possible) ground strap about a foot long. Ground the transmission and frame with it. Take all of your little ground straps off and clean the ends to bright. (Like the ones from the Engine mount to the block. Take the solenoid off the starter and carefully turn the large brass washer around so that a fresh surface is available.
Re: The starter. The bolts holding it in are way over engineered. Replace them with shorter ones. Get a curved closed end wrench (5/8" I believe) to aid getting the starter on and off.
Sue has the right idea, and I'm dredging these tips up from when I drove a '41 back and forth to work, fifty miles each day. Best of luck. (That was 54 years ago.)
Hello Barry,
could you please explain, why you changed the bolts against shorter ones? You said the original ones are a little over engineered.
Maybe I understood it in a wrong way.
Regards Oliver
1932 Cadillac 355B emergency vehicle
1946 Cadillac Series 61 Coupe
1958 Chevrolet Bel Air 4door Sedan
1958 Wartburg 311 4door Sedan 900
1961 Wartburg 311 4door Sedan 1000
1963 Trabant 500 2door Sedan
1989 Trabant 601 2door Sedan
1966 Bulldozer T 100 MGP (sold to a museum)
1968 Bulldozer T 100 MGP
1998 Nissan Pickup Navara
2015 Ford Ranger Pickup
1978 MZ T 250/1
1992 Harley Davidson Fat boy
