1953 Cadillac 60-Special "The Muskogean Phoenix"
Started by kudims, December 16, 2024, 04:16:03 PM
A friend in Germany used also this technique. The results are really impressive and the floor from this '53 car is in a super condition. One exhaust tube after the resonator may have tiny holes. A shame after just 71 years!
kudims
Quote from: Lexi on December 18, 2024, 11:48:21 AMWas an industrial dry ice blaster used or a less costly DIYer model? Happy with the results? Clay/Lexi
Industrial with 35kw air compressor
kudims
Quote from: Roger Zimmermann on December 18, 2024, 11:59:54 AMA friend in Germany used also this technique. The results are really impressive and the floor from this '53 car is in a super condition. One exhaust tube after the resonator may have tiny holes. A shame after just 71 years!
Exactly. I show this to have an understanding that low mileage car garage kept could be with zero rust.
Exhaust yes, it was with the mesh holes in tailpipes
kudims
#23
Let me start with re-animation of the power steering pump and gear.
Restoring the Power Steering Pump
When I picked up the car in Montana, I wasn't impressed with how the power steering performed—it was essentially non-functional. I didn't have time to investigate on-site, so I removed a pump from another 1953 Cadillac sitting in Ross's junkyard, drained its oil, and tossed it in the trunk as a spare.
Once back home, I leisurely ordered a pump rebuild kit (seals, bearings, and O-rings) and found a rotor repair kit on eBay, though I held off on purchasing the rotor itself—and I'm glad I did.
This is the story of how I repaired two pumps in parallel. The pump's design is simple, reliable, and highly serviceable. It can be disassembled and rebuilt with basic tools.
The Process
The pumps, both the one originally installed and the spare, looked terrible externally, with oil leaking steadily, if not in streams, then definitely in drops. Despite this, the fluid level in the reservoir hadn't dropped during the 2,200-mile trip across America. According to the manual, the pump runs on automatic transmission fluid.
After cleaning the pumps, I disassembled them, revealing that the working surfaces of the pump chambers were in perfect condition.
One rebuild kit contained enough parts to refresh not just one but both pumps! The only exception was a single set of bearings, but since the original bearings were in excellent condition, I opted not to replace them.
Reassembly Highlights
Pressure Relief Valve: The bypass valve adjustment is made using washers. I left the factory setting intact but disassembled the valve to apply thread sealant to the plug, which was loosely secured.
New Seals: I installed fresh seals, ensuring tight, leak-proof connections.
Bearings: The external bearing on the shaft, made in the USA, was in excellent condition and reused.
Chamber Assembly: The chamber's "nipple" marks the left side, and arrows indicate the direction of rotation. Lamellae (vanes) have one sharp side and one smooth side; they must be installed with the smooth side facing outward.
Final Steps
Between the pump casing sections, I placed new O-rings from the rebuild kit.
The rear of the pump has a valve rod seal and a retaining ring, which I secured during assembly.
Once fully assembled, I thoroughly cleaned the pump and its components, preparing them for painting.
All components were painted separately before final assembly. To ensure reliability, I used polyurethane sealant (designed for Mercedes engines) instead of relying solely on cork gaskets.
The Result
The pump is now restored, clean, and painted. The brackets and all other components shine like new. This level of detail will apply to every part of this Cadillac.
Once reassembled and mounted on the engine, the pump looked slightly out of place—but this is only the beginning of the restoration journey.
I hope many people are already aware that a critical factor determining whether your power steering pump will generate pressure is the thickness of the O-ring at the pressure plate. If the O-ring is too thick, it can "leak" into the chamber of the steering pump when the bolts are tightened, preventing the pressure plate from making firm contact with the rotor body—resulting in zero pressure being produced.
Quote from: kudims on December 18, 2024, 10:20:37 PMI hope many people are already aware that a critical factor determining whether your power steering pump will generate pressure is the thickness of the O-ring at the pressure plate. If the O-ring is too thick, it can "leak" into the chamber of the steering pump when the bolts are tightened, preventing the pressure plate from making firm contact with the rotor body—resulting in zero pressure being produced.
I'm glad you understood this. Yeasrs ago, a man went almost mad just because this O-ring was too thick. I still don't understand why the kit producer is still including the thicker O-ring.
kudims
Quote from: Roger Zimmermann on December 19, 2024, 02:41:48 AMI'm glad you understood this. Yeasrs ago, a man went almost mad just because this O-ring was too thick. I still don't understand why the kit producer is still including the thicker O-ring.
It took me a while to understand the issue. Finally, I found videos on youtube, which have directed me on a right path, but the guy was not explaining WHY it matters so much. And this is what I have understood as a PhD in math & physics :-)
kudims
Restoring the Power Steering Gearbox
Before I started, I had already purchased a rebuild kit, which will come into play later in the story. Now, let's dive into the fascinating complexity of this component.
The power steering gearbox is both simple and complex. Simple, because it was the first steering gearbox with power assistance designed for civilian vehicles. It has separate modules: a worm gear mechanism with its own rack, a spool valve mechanism, and a hydraulic cylinder with another rack that directly acts on the pitman arm. Complex, because these modules interact across separate housings, connected by multiple seals, and require precise adjustments to function correctly.
Disassembly and Inspection
The spool valve mechanism was cleaned in acetone and sprayed with WD-40 to prevent rust. Its plungers and springs were stored in a separate bag for safety.
The seals from the rebuild kit for both the spool valve and the pivot shaft fit perfectly.
Needle bearings and bushings were in excellent condition and did not require replacement or reaming.
The spool valve mechanism was carefully reassembled, with a focus on ensuring all seals and components fit correctly. A weakly tightened plug in the valve was seated using thread sealant to prevent leaks.
A secondary seal for the steering shaft, which wasn't included in the rebuild kit, had to be purchased separately.
The piston in the hydraulic cylinder was carefully cleaned, and its new seals were installed. The sealing ring fit tightly into the cylinder's precisely machined opening, designed to hold pressure without leaks.
The rack and sector gear clearances were adjusted using the factory method, which involved stacking thin steel shims. Adding shims increases clearance, while removing them tightens the fit. This design, while innovative at the time, was replaced in 1954 with a threaded adjustment plate, which would have been far more convenient.
Challenges and Adjustments
The rebuild kit included all O-rings but had a major flaw: the thickness of some O-rings didn't match specifications. While 2.6 mm and 3.6 mm rings were required, all included rings were 3.6 mm. This required sourcing correct-sized O-rings separately, adding a few days to the process.
Original GM gearboxes were known to leak over time, as they used a thick, viscous oil (similar to gear oil) in the gearbox and ATF in the hydraulic system. Dealerships often replaced the oil with grease, solving the leakage but sacrificing proper lubrication. I opted to maintain the ATF system, ensuring all seals were perfect to prevent leaks.
Final Steps and Results
The hydraulic cylinder was reconnected, and the pivot shaft clearance was adjusted precisely.
To prevent leaks at the shim-packed adjustment points, I sealed the edges with a polyurethane sealant.
Once fully assembled, the gearbox looked much closer to its original state, both in functionality and appearance.
Now, the power steering gearbox is ready for action, combining original design integrity with modern sealing techniques to ensure reliability and performance.
kudims
And... Paint job...
Finally: Installation on a car. The front end should be lifted so that the front wheels will be at least 10 inches above the floor
The power steering and the steering gearbox work excellent. Sahara dry from outside, which makes me more than happy.
It seems that you are using sealing material (like silicone) which was not intended when the car was new. If a sealing product may help to avoid leaks, it can also do some harm, as the excess material is going inside the device. It's not uncommon to have malfunctioning transmissions because some surfaces were sealed with an unappropriate material which went into the oil cicuit.
kudims
Quote from: Roger Zimmermann on December 20, 2024, 03:34:31 AMIt seems that you are using sealing material (like silicone) which was not intended when the car was new. If a sealing product may help to avoid leaks, it can also do some harm, as the excess material is going inside the device. It's not uncommon to have malfunctioning transmissions because some surfaces were sealed with an unappropriate material which went into the oil cicuit.
I try to put this polyurethane sealant on surfaces so that it will not go inside, because yes, the issue is common, when people are over-enjoying silicone...
But this is not silicone, this is the sealant for Mercedes engines, which are assembled without gaskets - only sealant
kudims
#30
Replacing all vacuum hoses + Trip odometer repair
The vacuum hoses on this car are 70 years old. Surprisingly, the rubber is still in great shape—no cracks or signs of aging. I didn't throw them away, so I carefully coiled them up and stored them in a box. However, the connections to the fittings had loosened over time, causing minor leaks. Instead of clamping the hoses, I decided to replace all the hoses with new ones, both in the engine bay and under the dashboard.
To get easier access to the wiper switch (and the washer button nearby), I partially disassembled the instrument cluster. It only took about three minutes—everything is surprisingly convenient for a car from the 1950s.
The wiper switch has a smart design. A long rod from the washer button connects to its center, and turning the outer hex head opens a vacuum valve for the windshield wiper motor. Once everything was accessible, it made the work much easier.
Since I was already inside the instrument cluster, I decided to clean all the glass faces and polish the chrome bezels. I did fix the trip odometer, which likely hadn't worked since it was new.
The issue was a retaining ring on the shaft that wasn't seated correctly. This created too much play between the rings, so they would sometimes turn and sometimes not. Using a special tubular tool, I nudged the ring about 1 mm (maybe less), and now the digits flip perfectly, one after the other.
I repainted the scratched shift indicator needle for the automatic transmission.
All original fasteners were stainless steel. Due to chrome shortages during the Korean War, many trim pieces on this car were made from polished stainless steel, including the fasteners—a testament to the era's challenges.
The instrument cluster is now fully reassembled.
I also hung some pictures on the garage walls — mostly pictures of my previous car.
As usual, the workbench is cluttered with "extra stuff," but that's just how it goes!
Now I am confident that there are no vacuum leaks, so it's time to inspect all the aux equipment, powered by vacuum: antenna, wipers, windshield washer
PHIL WHYTE CLC 14192
That was me and Art who had that problem. It took me over a year to diagnose as I just couldn't put up with it not working, I walked away and left the car. Art hit the same problem and I suggested the new seal that was thicker than the original was the problem so we both switched them at the same time and they both worked perfectly.
Phil
kudims
#32
Let me dissolve technical content by posting few pictures from the trip Montana - Texas. First is from Yellowstone, second is from Amarillo, Cadillac Ranch
Sorry Phil...I remember your story, but not which person who had such a problem...
kudims
Rebuild of Fuel & Vacuum pump - not worth it - buy NOS
The fuel pump on the Cadillac engine is located in the engine valley—a less-than-ideal placement even by 1953 standards. Here's why this positioning is problematic:
Heat Exposure:
The pump is constantly exposed to hot air from the radiator and is nestled in the engine valley, much like being in a kangaroo pouch. This setup guarantees overheating issues, but that's only part of the problem.
Fuel Boiling:
The bigger issue is that fuel begins to boil in the line before it even reaches the pump. This happens because the fuel line runs along the front of the engine, where it's exposed to high temperatures.
As a result, even a perfectly functional fuel pump struggles to operate under these conditions, leading to fuel delivery failure. This becomes particularly noticeable during city driving, with low airflow and frequent stops at traffic lights. After shutting off the engine and letting it sit for 10–15 minutes, restarting the car can become impossible without dousing the fuel pump and fuel line with a significant amount of water to cool them down.
Here is the pump removed from the engine:
Here is a rebuild kit:
Disassembled and cleaned:
Flattening the flange:
Looks good:
Pulling some valves off was a challenge. Here is the 2-minute made custom puller:
One valve had to be customized... shame on the kit producer:
Reason - pump body has this:
Assembled:
Installed on the engine:
But this is not the end of the story... because:
1. The pump was making clunking noise at low RPM (380-400) while hot
2. The axle was leaking
The leak was fixed by replacing the axle with the 1/4" stainless bolt + little of polyurethane engine sealant
The axle from the kit:
With this, it stopped leaking
But the noise was still there...
Solution of that problem tend to the purchasing of the new pump:
Original gasket with a narrow hole in the center - only for the arm and a round hole for the oil drainage:
With this - you are good to go:
And... this is the picture from the recent time. Looks good, works perfect:
Finally, this is only my advise... but don't spend time for rebuilding the mechanical pump since you can find NOS on a market. Not worth time spent.
My only thoughts about anything NOS with relation to fuel is that the original diaphragms will not be compatible with the latest ethanol-laced fuel.
 My thoughts too!  Wouldn't trust an NOS pump that old with its old diaphragm when put up against ethanol laced fuels.  Actually that diaphragm may well be dried out and won't last long with any fuel, ethanol or not.
kudims
Quote from: The Tassie Devil(le) on December 22, 2024, 06:02:22 PMMy only thoughts about anything NOS with relation to fuel is that the original diaphragms will not be compatible with the latest ethanol-laced fuel.
The same thoughts I had.
I contacted that guy, who is specializing on selling these new pumps, on a subject - do I need to replace valves or diaphrahms... and he said that I am good to go as is. 6 months... no issues yet. Will see
kudims
#38
Radio Antenna: Restoration and Creative Engineering
The radio antenna on the 1953 Cadillac is mounted on the left front fender. It features a single telescoping section and a vacuum-driven mechanism controlled via the radio itself. The right-hand knob on the radio is multifunctional: turning it adjusts the balance between the front and rear speakers (stereo wasn't a thing in 1953), pulling it raises the antenna, and pushing it lowers the antenna.
After replacing the vacuum lines, I decided it was time to investigate why the antenna refused to move up and down without manual assistance.
Initial Observations and Dismantling
The antenna was removed for inspection. An interesting quirk of its design is that it doesn't fully retract—a 15 cm section always remains visible. Additionally, the telescoping section can only be extended manually, meaning it's not fully mechanized.
The antenna housing, which acts as a cylinder, is made of aluminum. Disassembly required careful handling, so I brought out the heavy artillery—a bearing separator tool. I secured one side to the housing using a split pipe, while the other pressed against the decorative nut.
It looked a bit ridiculous, but it worked flawlessly.
Diagnosing the Issues
The antenna had two main problems:
1. The housing was dented in three places, causing the piston to stick.
2. The shaft seal had hardened into a brittle material, similar to vulcanized rubber, and was leaking air.
I spent an evening brainstorming how to restore the housing to a perfectly smooth cylindrical shape and finally came up with a solution.
Repairing the Housing
The internal diameter of the housing is 40 mm, with the dents located about 30 cm from the edge. Here's where creativity came into play—I repurposed a CV joint ball (23 mm in diameter) from an old repair project, solving a small geometry problem to create a tool.
Using ¾-inch plywood, I drilled a 12 mm hole to house the ball, ensuring it would touch only the circle's edge. I then shaped the plywood to optimize its fit and functionality.
The ball, paired with silicone pipe assembly lubricant, allowed me to smooth out the dents. Supporting the cylinder's outer surface with adequate pressure prevented further deformation while ensuring proper friction for the repair. After a few longitudinal and transverse movements, the housing was restored to perfection.
Additional Repairs
Cleaned the antenna base, which features a petal-style rubber valve that was tested and confirmed to be operational.
Replaced the shaft seal, which turned out to be two O-rings. After scouring my treasure trove of spare parts, I found suitable replacements and installed them with a bit of silicone lubricant.
The shaft and piston now move freely, emitting a satisfying sound reminiscent of a bus door opening.
Finishing Touches
Cleaned the antenna's primary brass element until it gleamed.
Reassembled the entire antenna and inspected the manufacturing numbers and date for documentation.
The antenna is now fully restored, operating smoothly and reliably.
Final Thoughts
This project was a mix of precision, patience, and creativity. Finding unconventional solutions, like repurposing a CV joint ball, turned a tricky repair into a fun engineering challenge. Here's wishing everyone the ability to discover creative solutions to any task!
kudims
#39
Restoring the "Autronic Eye" Automatic Headlight Dimmer: A Journey Through Vintage Tech
It's no revelation to say that a premium car can only truly be considered premium if every feature designed by the manufacturer works flawlessly. That's the philosophy guiding my work with Phoenix, my 1953 Cadillac, as we methodically restore it to full operational glory.
One such feature is the "Autronic Eye," Cadillac's automatic headlight dimmer. When I bought the car, the system wasn't functional. A full day of troubleshooting, wiring work, and careful adjustments finally brought it back to life.
Understanding the System
The Autronic Eye operates through a combination of relays, vacuum tubes, and a photosensitive "magic eye" sensor mounted on the dashboard.
A foot pedal toggles the system on or off, allowing the Autronic Eye to decide when to switch between high and low beams.
A second foot pedal enables manual override for high beams or flashing.
The schematic in the service manual shows a relay that integrates with the floor switch and Autronic Eye amplifier.
Diagnosis and Initial Repairs
Step 1: Relay Troubleshooting
The relay was disconnected, with wires hanging suspiciously loose. Upon inspection, I found the internal rivets had failed, and all contacts were loose.
I fabricated a new clamp from galvanized steel, threaded it for screws, and reassembled the relay with threadlocker and polished contacts using 2000-grit sandpaper. The repaired relay was mounted back on the Autronic Eye amplifier bracket.
Step 2: Wiring Puzzles
When reconnecting the relay, I noticed the wire colors didn't match the manual exactly. Three wires were close, but the fourth was clearly incorrect. I assumed the factory might have run out of matching threads for the fabric-insulated wires. I connected everything as best I could—no luck.
Reading further into the manual, I learned the system could operate like a standard manual headlight switch by bypassing the Autronic Eye. Testing this idea, I traced the floor switch wiring and unwrapped sections of dirty insulation to find colors matching the schematic. The puzzle pieces began falling into place.
Step 3: Bypassing and Testing
I temporarily disconnected the amplifier and wired the system to bypass the Autronic Eye. With the fuse removed, the floor switch functioned perfectly, and the relay clicked on cue. This confirmed the wiring was now correct, but the amplifier or sensor was non-functional.
Fixing the Amplifier
The amplifier boosts voltage to 150V and 1,000V for the sensitive light-reactive tube. The manual stated the first sign of amplifier failure is a silent vibrator.
Disassembling the vibrator revealed intact coils but dirty contacts. Cleaning them with 2000-grit sandpaper restored functionality.
Upon reassembly and power-up, the vibrator buzzed to life.
Testing the System:
After a minute of warm-up, I tested the manual high beam switch—it worked perfectly. Holding my hand over the Autronic Eye sensor triggered the high beams, while removing it switched back to low beams. Success!
Final Adjustments and Road Tests
Reassembly included securing the amplifier cover, which conveniently housed an electrical schematic, and mounting the floor switch back in its original location.
The system has two adjustments:
Hold (on the amplifier): Determines the delay before switching beams.
Dim (on the sensor): Adjusts sensitivity to light levels.
The service manual recommends using a Kent-Moore Guide Autronic-Eye Tester Model 10, but road tests revealed the system was functioning correctly without further adjustments.
Conclusion
After meticulous repairs and testing, the Autronic Eye is fully operational, switching beams precisely and reliably. This restoration not only brings back a unique feature of the Cadillac but also reinforces its status as a true premium car of its time. Vintage tech might be finicky, but when it works, it's pure magic.
