1959 cadillac sedan deville "easy restoration"
Started by Roman_cadillac, December 21, 2024, 06:03:08 PM
Roman_cadillac
Next comes painting
factory color "red oxide"
Roman_cadillac
After painting the body, the work underneath
was completed.
Some of the body paint was sprayed underneath as at the factory
Roman_cadillac
Roman_cadillac
Next I applied the coating approximately as at the factory
I took the photo of the car with the factory coating from this forum
Roman_cadillac
Roman_cadillac
G'day Roman,
That is what I call, going above and beyond.  As you have found out, Sand Blasting will simply bounce off any rubberised coatings like seam sealer and sound deadening, as well as grease.
One thing that I have found is that when any electrical connection, be it a ground or anything where paint is applied, these spots need to be devoid of paint or you will be chasing wiring issues for a long time.
Remember that the original paint was really thin, and the final proofcoating was applied after the car was assembled.  This meant that any electrical connections (Grounds) hit metal when they were screwed into the body or chassis.
James Landi
Terrific effort--- well done..Enjoying your pictures... (those flexible brake lines look old and dangerous though!)
Roman_cadillac
Quote from: The Tassie Devil(le) on December 22, 2024, 06:22:48 PMG'day Roman,
I agree! I installed grounding strips. They connect the firewall and the engine.
Roman_cadillac
Quote from: James Landi on December 23, 2024, 07:35:25 AMTerrific effort--- well done..Enjoying your pictures... (those flexible brake lines look old and dangerous though!)
It is better to do this with a lift.
Roman_cadillac
After painting, the frame was delivered and assembly began.
The suspension parts are sandblasted and painted with polymer paint
New suspension patrs! Shafts and ball joint
All screws and fasteners have been replated
Roman_cadillac
#31
Before installing the shaft bushings, it is necessary to spread the suspension arms
I made a homemade spreader
I tightened the bushings with an impact wrench.
OEM lower arm bumpers
Assembled suspension arms
Roman_cadillac
Oil shock absorbers sandblasted and painted
Oem coil spring sandblastged and painted
The springs are marked with gray paint as at the factory.
Assembling the front suspension using studs of different sizes
Spring insulator
Roman_cadillac
James Landi
It's interesting to note that during the 1961 model year the upper control arms were re-designed, and king pins were gave way to ball joints. During that period, our family had a '60 and a '61, and the differences were noticeable. I concluded that while the change over provided more precise steering and less "float," the redesign required less tire pressure (spec at 24 ft and 22 rear) to provide less harshness.  Thank you for sharing your journey with us Roman.   James
The king pin was used till 1956. From 1957, ball joints were used on the front suspension.
Roman_cadillac
After the front suspension, restored the steering All steering elements are original, except for the steering tips and pitman arm. All hardware is zinc coated. Springs are oxidized
These parts are not in very good condition. I don't quite understand what they are for.  I left them as is
The problem on 1959-60 Cadillacs is a defective pitman arm. There was a recall
I couldn't find numbers on the pitman arm. My Cadillac is an early 1959, all the parts where the date is visible are stamped 1958. I think the pitman arm was not changed. I replaced it.
Wanted to install a new idler arm. The new arm had more play than the factory one. Unfortunately, the new parts are much worse than the factory parts. Sandblasted, painted and installed the original idler arm.
Everything is easy to assemble
It is important to align the triangular spacer to match the holes for the oil press
Roman_cadillac
My friend re-sealed and adjusted the steering gearbox.
I sandblasted and painted it
The steering is installed
Cadman-iac
Roman,
 The purpose of these stainless steel cups is to prevent your grease from leaking out around the holes where the pitman and idler arms go into the center-link assembly.
 When I rebuilt the steering on my 56 I couldn't figure out what purpose those things served either, until I went to grease everything, then it became obvious.
 The dust covers around the pitman arm ball and the idler arm ball being metal with no actual rubber seal of any kind just keeps the dirt from getting into the openings where the grease comes out. Without the cups installed, the openings are bigger than the dust shields and your grease is exposed to the elements.
 I couldn't find new ones for my car and figured they weren't really necessary so I left them out. It was only when I began to pump the grease into the fittings that I realized what they did.
 I even tried to find someone who could make new ones but nobody was willing to try or just unable to.
 So yours don't look too bad, I'd just reuse them. You'll regret not putting them in.
 Nice job on your car too. I like the abundance of pictures. Thanks for posting them.
 Rick
CLC# 32373
kudims
Roman, tell us what was next in your project, please.
