1995 Fleetwood Brougham "The Grey Ghost"
Started by kudims, February 13, 2025, 01:03:49 PM
kudims
Quote from: The Tassie Devil(le) on February 21, 2025, 07:39:26 PMDon't you hate it when people shortcut and don't repair properly.
Don't expect anything extra from ordinary people 😁
kudims
Sandblasting
The frame and underbody will undergo sandblasting, providing a clean slate for exceptional future work.
50 kW compressor with the diesel engine
It was done in front of my home shop at the backyard
The car was on old tires and non-chrome rims
Totally 1.5 tons of copper slag was used
It looks terrible, I understand
Finished. In garage already
And this is the only problem that was found
Front crossmember. Remember how it was
kudims
Preparing for paint job
The body was raised and the frae was lowered
To prevent bare metal from fast corrosion, a special solution on a formic acid was used.
The metal becomes dark after such treatment, and resistant for further corrosion
The corroded hole in the body was cured using aviation technologies: a piece of metal + steel rivets
+ body sealant
Final look
Another portion of hardware that goes to sandblasting and powder coating
Body sealant was used on drain plugs
The frame after one coat of black hammered enamel, which has corrosion inhibitors
Phosphoric primer
Antigravel coat
Firewall was coated up to the welding stitch
Antigravel coat
Final coat
The body on GM vehicles was painted with RAL7033 color (cement grey), and only from outside it was painted with exterior color. So, every vehicle, regardless of exterior color, has grey underbody and floor inside.
I used 2K acrylic coat
The edge will be hidden with the firewall insulation
This is the location of the front alignment pin, which is used to position body on a frame
Looks much better than before
Front suspension will go soon to the sandblasting
2K final coat is needed to cure all the pores on antigravel, as antigravel can't be the final coat
Rear alignment pin location
Bottom of the trunk
Rear frame crossmember
Impressive work. Something I'm wondering since some time: apparently, the license plates are Russian. But where did you perform the work? In Russia or the US?
kudims
Quote from: Roger Zimmermann on February 23, 2025, 12:55:42 PMImpressive work. Something I'm wondering since some time: apparently, the license plates are Russian. But where did you perform the work? In Russia or the US?
It was in Russia, and I had to sell this car in Russia before relocation
kudims
Rear axle
As I mentioned earlier, one of the axle shafts was irreparably damaged. Fortunately, along with the car came another axle shaft—scored by a bearing but without any welds or attempted repairs—which is a huge plus, saving a lot of time and some money. Here's why: in the U.S., you can buy special TIMKEN repair bearings (model TRP1563TAV) that replace the factory bearings. The trick is that they ride on the still-undamaged portion of the axle's machined surface!
Left bearing - new original
Right bearing housing
This axle will be used from the passenger side. The problem is that these axles for 93-96 Fleetwoods are IMPOSSIBLE to find new. They just do not exist
The repair bearing must be positioned 1/4" or 6mm off the housing
Tool used  ;)
Once the bearing is in place, I double checked with a marker that needles run over undamaged part of the axle neck
Pre-assembling of the drum mechanisms
It's ridiculous how many people assemble these mechanisms not correctly, after which self-adjusters do not work
New cylinders and zinc-coated hardware
New steel tubes 3/16 with copper coat from inside and vinyl coat from outside
New nuts
Flaring process
Double flare
New MOOG bushings
Almost ready. The brake hoses are still old, as new ones were not yet delivered
And, some miscellaneous items...
New fuel sender mesh and transmission pipes recieved
Now it's ready to go in tank
Positioned and tightened
Pressure regulator (for variable effort steering) on the steering pump was not oriented properly
This is how it should be
Fixed, cleaned, o-rings changed, painted
Then I started fixing all the terminals on underhood wiring
New terminals come with a 10 inches of wires, so you unwrap the braid, solder new, wrap again
Almost every connector had to be replaced
Some details of the process
All those o-rings had to be replaced
All hoses for the power steering have to be isolated, because if they are not, and if they are touching the frame, you will notice noise from steering gear
Hand brake cable - sealed
New cables for the rear drum brakes
Looks better and better
kudims
Some things to be done before "wedding"
Steel part of EVAP system pipe was put into self-wrapping vinyl
To prevent wear, the part that goes into the frame was protected with crimped sleeve
This is how it looks on a frame
And finally I put back in place the EVAP canister, from which the whole process has begun
Left side: new brake lines. More details about brake lines
Bender for 3/16 tube. Works good. Black mark corresponds to the center of the bended radius
I used the plastic straps to fix the tube and repeat as close as it is possible the trajectory of the original tube
Another device (right corner) was used to secure the tubes
Almost done with one pipe
The trajectory is very complex, so securing both tubes together is a must
Short tube to the right wheel
Just the same process
I mark the center, then slip the strap a bit to have more flexibility, and bend in the proper direction
Done
Simple flaring tool
Mushroom flare type. By the way, both types of flares are used on this car as well as both imperial and metric inverted nuts for the brake lines!!!
Anti-lock brake system assembly
Installed
Start wrenching the pipes
All done
Here is the vinyl protector against shortcut between the tube and ABS positive terminal. Factory solution
New line to the right wheel
Brake lines to the rear wheels
I don't know why, but this is the correct bending... Factory pipes were also not just straight along the frame
New fuel filter and wiring to the ABS sensors and suspension level
There will be a connection with rear brakes hoses
Terminal for the rear right ABS sensor
EVAP line
Almost ready to connect body with the frame
Hardware
More hardware
After powder coating
New frame bushings
Steering shaft assembly. I had two of them. there was a need to replace the boot from one to another
Ready to be installed
Cracked boot
More parts have returned from the powder coating.
tcom2027
Good morning,
Spectacular job. What is equally impressive is you did it outside the US. I can't imagine the difficulty you had sourcing parts.
I like your indicator mount. My mill has been idle for a couple of weeks. Time to give it some exercise.
 We had a '96 Brougham for many years. SAme color, It was fast, reliable, easy on fuel, 22-23 highway, 14-15 in town and uber comfortable. When we sold it in 2016 it had 266,000 miles on it. Very little oil consumption, a quart every 5000 miles when it got changed. No drive train problems. Normal maintenance items and few electrical glitches. We live in mountain country. Six percent grade,four people,sixty miles per hour,wanna go faster,simply press the foot feed a little harder. No drama.
My wife drove it and as we got older it became ,in her words,"difficult to dock". She drives a Northstar engined Deville now.
Congrats on a fabulous job.
tony
kudims
Wedding
All 16 washers for the body mounts were sandblasted
Then they were painted in correct blue original color. The picture does not represent the true shade
New bushings and powder-coated mushroom type sleeves
Here they are. All marked
The sequence is the following (one side, from front to the back): D2, D3, D1, D2, D3, D3, D3
Put them in the correct sequence
Start lifting the frame with 2 jacks. One in the front, one under the rear crossmember
Alignment pin = socket extender with 1/2" square
Another jack
And another alignment pin
Tighten to the frame @ 70Nm
Rear suspension
Two sets of lower arms. One set was enforced
Like this
Also, these arms are really weak near the bushings. We have enforced it there as well
According to the Manual, you need to flare the bushing sleeves in 3 places at 120 degrees
New coil springs and new washers
Use polyurethane glue to secure the washers
And... the car is on its wheels
Bolts for sway bar
And here we go
Take all the pieces from the shelf
And put them back on a car
Looks different from what it was
The attentive reader will notice that the coils are put with the opposite side up ))) Not a big deal to change it
Air lines connectors
Against wear and noise
Hide them inside the frame
Made extra pigtail
Airline in protective sleeve goes inside the frame
Bolts on the arms will be tightened once the car will have its full weight
kudims
Front fender splash shields after powder coating in correct black satin
I decided to coat them in anti-gravel + 2K clear coat from the wheel side
At the same time I wanted to keep them just matte black from the engine bay side
The part that will be invisible inside the fender was also coated
The edge of the anti-gravel is not equal to the edge of clearcoat. Clearcoat is broader
From inside
Now fender assembly. Inner + outer parts
Use simple pins to position parts correctly
New protective shields
Meanwhile, power steering lines were secured at the front crossmember
Now fixing the firewall insulation. I used non-damaged piece from another insulation that I had
And covered it with a special material
New butil sealer on heater pipes
Covered by the decorative square piece
And then I put the insulation back in place
This part, which was restored, will be almost invisible after full assembly
Not new (new is impossible to find), but still much better than before
Front suspension goes to sandblasting and black powder coat
This hardware goes to the zinc shop
Now let's turn our attention to the rear end...
This is the damaged enforcement of the rear bumper
Broken pieces that need to be fixed somehow...
I used 2 pieces of MDF clamped to the enforcement, also I drilled many holes and put there 1/8" steel wires
Prepared for the epoxy cure
This channel will be filled with epoxy
Mixing
Syringe will be used for pouring
Pouring process
The remainings of the epoxy started to heat (hardening process), and rapidly the syringe had melted ))), which means that the epoxy is good
Next day view
Exactly what I wanted to have
After some sanding
Ready for paint
Painted in black matte
Hardware for the bumper assembly
Installed on a car
The enforcement looks good
Almost as new...
Right rear quarter chrome panel installed
kudims
Front suspension
Some parts after powder coating
Some NOS parts from 1980-s (Cadillac and Chevrolet suspensions were unchanged in 80-90-s)
Instructions
Ball joints
Installation of bushings
Installed
Ball joints have orientation
Ready to go
Lower arms bushings
Using special spacers in order not to damage the arm
Pressing in
Mount inboard
Coils are specific for Fleetwood and are different from Chevrolet
Mercedes-Benz spring compressor
New bearings and seals
Adjusted as per manual
New caps
and press it in using the tool
Brake pads - Raybestos Element3 - the best in class
These pictures do not need any comments
Shocks that are excellent for Fleetwood. Both steering and soft ride in one can
How about that?
Scroll to what it was before
Tightening torques
Correct orientation of steering links
Idler arm correct adjustment
Hello, Ukraine. That was done in January 2022
Mark all the bolts and nuts to easy monitor if they become loose
On wheels again
James Landi
Impressive discipline and workmanship.  As you roll out these images, it's clear that you left nothing untouched.
kudims
Now start working on engine
Water pump: I had a new ACDelco "Made in China", though I decided to reuse the one that was on a car, as the pump was changed not long ago by he previous owner, and it was GM Genuine
However, the o-ring had to be replaced
New o-ring must be 2.4mm thick ~0.1"
Bolts after black plating
Ready
Throttle body was almost ok
But still needs to be inspected
Washing and cleaning process
Now it's clean inside and outside, new gaskets installed
New engine mounts installed, but the engine is not ready yet
Some stuff goes to replating
Received
Intake manifold studs in the proper order
Dirty
Start washing with high Ph chemistry
Done
The best I could do
Intake has many internal passages, which were hard to reach, but I tried
Inside view
Thread sealant for the plugs
Lower plate mounting
The top stripes were polished
Installing brackets after paint job
PCV valve
All vacuum plastic tubes were cracked. I replaced them with steel tubes and rubber fuel-resistant hoses
With fuel injector nozzles after ther were washed on ultra-sonic setup and tested for the productivity and leaks
Of course, new o-rings were used for the fuel ramp
One more component for today: Ignition
Rusted and corroded central electrode
New coil, brackets after replating
Ignition module needs good cooling, otherwise LT1 will not work
I decided to use stainless hardware instead of original steel rivets
Assembled.
Harmonic balancer
kudims
Underbody assembly
New brake hoses on rear axle - installed
They come in protective sleeves
Install the brake booster and connect all lines
Now ready to install the fuel tank. 1/8" rubber was used as an insulator
Looks new
Connect fuel lines to the sender unit
Ready to install heat shields
Two in the front
Two above mufflers in the center
And two in the rear protecting the fuel tank
With firewall insulation above
Some additional techno-porno
Shock and frame bushing
Left muffler hanger
Overall view
Clean inside the shop and get ready to work with the engine
Some hardware for the future posts
kudims
Engine LT1 350 cid @ 265 hp
I'd like to make a small disclaimer so there's no confusion about what I'm doing with the engine.
Over two seasons and roughly 500 miles of total driving, I've kept a close eye on the car. The engine has proven to be in perfectly good condition. There is no oil consumption, the exhaust pipes are free of buildup and actually show some rust inside, there are no unusual sounds, the power is excellent, and the ignition and injection systems are functioning as intended. Tearing into an engine like that for anything beyond basic gasket and seal replacement is just childish curiosity along the lines of "I wonder what's inside".
Take the engine from the "parking lot"
And start washing it
Let it dry, let it dry, let it dry
With a steel wire brush on an angle grinder, I have removed all the unconsolidated rust from the engine
Then I took special high temperature paint over rust cast iron, and made 2 coats
I rotated the crank to the vertical dead point of 6-th cylinder, and removed the balancer, marking the correct position
Bath for internal cleaning
Some deposits and sludge over the last 25 years
Different types of chemistry + brush + patience give the result
Some parts for the engine and other
Cracked flywheel
The left manifold's fasteners were converted from 3/8-inch to M10 due to a previous "hack job." The only fix was to re-tap the holes to the nearest metric size, since the closest inch thread was too far off nominal. One of the second-to-last holes in the head was so badly damaged that it needed to be tapped M11×1.5. Because ARP doesn't make M11 bolts, I bought a set of M12×1.5 bolts and turned one down to M11
But finally it was looking almost good
New gaskets
Covers after powder coating
Wash all stickers
And mount both headers on the engine
I used FelPro gasket kit, and I was pretty happy with it
Both o-rings on the oil filler extension tube and the cap were replaced
New connector
Comes to the PCV system
Oil pan with new level sensor
Clean inside, shining outside
Guides for the oil pan
Manual says that there is a need in engine polyurethane sealant in the corners
Oil pan bolts and nuts after plating
And this is how guides help to put all together
Ensure that the pan is set correctly
New seal gasket on the level sensor
Tightened
New knock sensors
Optispark seal was damaged (and I guess it happened on assembly line), but there were no leaks there
New teflon seal. No lubrication is needed!
Pressing the front hub int
New spark plugs
New AC Delco GM Genuine wires
Just for the reference
Optispark vent connections
Vent hoses for ignition, which are critical for its functionality
Air pump stainless tube after polishing
Passenger side wires
Cylinders 6 and 8
Correct routing
Driver side wires
New oil cooler lines installed
I made threads in the drainage hole from the water pump, and screwed a piece of bended stainless tube. Reason: now in case of leaks the coolant will not go straight to the Optispark
I will put a hose here and let it go somewhere underneath the engine
New air pump
Installed
Ignition module and coil
Installing intake manifold
New gaskets and polyurethane sealant
New throttle gasket
Throttle heater
Gates 90 degree hose
EGR valve gasket
Nice view
New GM original rear main seal
Need to mention that I lubricated with ~1 pint of engine oil left side rockers, as they will be lacking until the pump will raise required amount of oil at the first start. Passenger side will be lubricated once you fill the engine with oil
Finally, all the torques
James Landi
Over two seasons and roughly 500 miles of total driving, I've kept a close eye on the car. The engine has proven to be in perfectly good condition... Tearing into an engine like that for anything beyond basic gasket and seal replacement is just childish curiosity along the lines of "I wonder what's inside".
You certainly attended to wear and service life issue though!
kudims
kudims
Front clip
So, the engine is in place, and now it's time to reassemble the front end so our dragster turns back into a car.
First, I install the radiator support (loosely mounting it on its frame pads). There were original factory shims between the pads and the frame, so for now, I'm using the same number of shims on each side as before. Next, I set the splash shields in place, bolting them loosely to the body and the radiator support—nothing should be fully tightened yet.
After the splash shields, the assembled front fenders go on. I loosely attach them to the body, the splash shields, and the radiator support. Nothing will fully line up until the hood is in place, so everything has room to shift around.
In practice, it all looks something like this:
There were four of us to attach the hood
These will be replaced
With these...
I used new original GM bolts for these bodies
Final alignments
Gaps match
Final result
Also, attach the front bumper cover and adjust it
New original clips
Engine bay
New headlights
And new grill
New transmission cooler line
in place
kudims
Cruise control adjustment
Fleetwood is one of the last GM cars equipped with a mechanical throttle, so all those components like the traction control regulator (part of the traction control system) and cruise control operate differently than in more modern vehicles.
If you simply connect the gas pedal cable directly to the throttle, nothing good will come of it. That's why there are two intermediary interfaces in the "gas pedal – throttle" link. The first is the traction regulator mechanism, part of the traction control system introduced at the time. Its job is to choke the engine if excessive wheel spin occurs. The second is the cruise control module itself, which adds or reduces throttle input in place of the driver.
The gas cable runs from the cabin to the traction regulator. From the traction regulator, the cable goes to the throttle. A separate cable from the cruise control also attaches to the traction regulator. All 3 cables need adjustment.
In simple words, two cables—one from a real driver and one from a "virtual" driver (cruise)—both want to control the throttle (yes, they're quite demanding!). At the same time, the traction regulator is part of the traction control system and must cut engine power at the PCM's command.
Few manual diagrams showing each component's function.
Adjustment
Adjusting these components means synchronizing all three cables so there's no unnecessary slack, and ensuring the throttle fully opens when you floor the gas pedal.
First, adjust the cable from the throttle to the traction regulator.
Press this button (requires decent finger pressure) and pull the cable's bowden out of the regulator.
See the pic for how the cable should look in the "non-adjusted" position.
Next, insert a 3 mm drill bit all the way down through the stacked discs, then use a 1/4-inch drive tool to rotate the mechanism clockwise until it stops. Continue turning until you hear several clicks.
At this point, the accelerator cable is under tension. Check it by flooring the gas pedal: the throttle plate should fully open. If it does, the throttle cable is adjusted.
Then, adjust the cruise control cable.
Flip the latch on the cruise cable, which loosens the bowden. Loosening the bowden = loosening the cable. Once loosened, snap the latch back in place.
While holding the throttle cable and the top disc of the regulator, pull the cruise cable just enough to remove any slack.
The manual shows the same process in a diagram.
That's it for the adjustments. With the pedal floored, the throttle plate fully opens, and the cruise cable has no extra slack that would cause "lag" while cruising.
Here are a few extra photos of the car in the garage:
Since the radiators aren't installed and fluids aren't filled, the front end sits higher than normal.
Sometimes, I play chess with my youngest.
I've installed the PCM bracket and plugged in the PCM.
Also hooked up the horns—four of them (two on the left, two on the right).
kudims
AC and Engine cooling lines assembly
Compressor was drained from the old oil. The oil was clear
New oil
Old vs. new
Set of o-rings and seals for the HVAC
Just in case if someone will need it
New pressure gauge and evaporator nozzle
New lines were sealed
Compressor installed, 240ml of new oil was added into compressor
Attach new lines to the evaporator coil.
Note that the stitch where the firewall insulation was patched is almost invisible
New condenser installed
15ml of oil was added into it
New expansion cooler tank
New radiator
Installed
Air deflectors
Front shields
New accumulator
New labels
Installed
New accumulator needs 100ml of PAG46 oil
Fans
One motor was replaced with the new one
Installed
And here in the engine bay we have everything ready to go
Now I will do some work with transmission - just a regular maintenance, nothing serious. Follow next posts.
