Rear leaf springs
Started by gatech1956, Yesterday at 09:19:30 AM
gatech1956
Are the leaf springs for the 54 to 57 Cadillac the same?
54 to 56 probably yes. But there are differences between models. Most probably, 57 rear springs are different because the frame is new for this year.
Sorry, I'm away from home and don't have parts list with me.
Warren Rauch #4286
#2
   It is more complicated than just model. 1957's are all by themselves. In 56 and 57 ,Cadillac used 2 suppliers .Complete springs interchange ,but types A&B have different profiles and ends.
      Most 1956 models are on their own. series 75,1954-56. do interchange. 1954 and 1955 generally are the same by model except convertible models,that you need to know serial numbers to get the right one. Models with air ,use heavy duty springs.  Cadillac Group# 17.0015
  My rule for used springs . Get the pair. From a heavier model in possible.
 For what its worth, they can't be considering load and spring rates.
Hollander (1959 book)  Rear Spring    #11;;  2 1/2 wide x25 1/2 front bushing center   to bolt x31 bolt to rear bushing center x  1 1/8  bushings
  fits:  Cadillac 54-57 , 58-59 Coml
  You can sometimes cold work an old spring. Take it all apart. Don't Heat! re-arch the leaves one by one (bend them to create  more curve). If they don't break,it will raise the car when put back together. Often short lived. My brother Ed, is still running a 1946 Chevy after 40 years and doing it twice.
Warren
gatech1956
Thank you for the information. I have one other question regarding the gas tank strap. I understand there are two lengths for the 56 Cadillac I have one for the 56 that is two long almost 40 inches, what the length of the shorter one for the 56 Coupe DeVille
