Seville STS93 - cooling system
Started by Hanna, January 26, 2005, 08:00:30 AM
Hanna
Thank you very much!
A good Cadillac’s service is hard to find in Poland .
I pay a lot of money for  repair and I have  problems all the time.  I changed   the radiator and the waterpump. Thank! Firstly I must change coolant!
Mike suggestion of air in the coolant is  OK.  I want to vent the cooling system but  I don’t know  how to do it.
greetings
Hanna
JIM CLC # 15000
01-26-05
Hanna, pick the hose that is at the highest point in the engine compartment.
Loosen the clamp, slip the hose off just a little to expose the area where the clamping takes place.
Drill a very small hole in the hard pipe that it connects to, the air will come out, then the coolent, push the hose in place and tighten the clamp.
Wipe-up coolent, you should be in business.
Good Luck, Jim
