58 Carter AFB with 3 step metering rods
Started by Doug Scarrow, May 23, 2005, 11:42:51 PM
Doug Scarrow
  I took on the project of rebuilding a carb for a fellow Cadillac enthusiast. This is a 2697S AFB with 3 step metering
rods. The originals are Carter part # 16-31 (.072-.066-.046)
they are badly worn and the mileage is suffering.
  My parts book shows 3 other alternate metering rods for this
 carb  : 16-58 (.071-.062-.040)
         16-59 (.071-.062-.040)
         16-73 (.o69-.063-.043)
  I am aware that carter used 3 step metering rods in later AVS carbs but these are longer and require raised vacuum piston
covers to allow for more rod travel.
  I would like to find a pair of correct rods to bring this carb
exactly back to original
JIM CLC # 15000
05-23-05
Doug, try the carburetorshop on the web.
Good Luck, Jim
John Washburn CLC #1067
Doug,
The web site is: thecarburetorshop.com
Generally the primary jets wear not the metering rods. I would pull the jets and make sure they are not out of round.
Either way Jon at the Carburetor Shop can provide the parts you need.
John Washburn
CLC #1067
Elizabeth, Colorado
