firestone 721 tires
Started by Viator Trudeau #8697, July 10, 2005, 11:57:40 PM
Several posts on the Tech./ Auth. sect. tells about tread separation on FS 721 tires.  Looked at my 721s while doing a lub. I looked at the front tires only.  Will one see some indication of a problem like a crack or some sort of a beginning loosening of the tread, like it would occur in the next 5o miles. Got mine mounted 2001 & have less than 5,000 miles on them. Any ideas.  Thanks
George Woodford clc21025
It is my understanding that Firestone reenforced the side walls of the tire with the introduction the 721 Series XL.  I think they added 2 extra ply to the tire.  It appears some people have had good service with these tires while other have had problems.  I believe it depends on the climate where the car is run.
