68 Eldo trans oiling.
Started by viator Trudeau, July 11, 2005, 03:43:10 PM
viator Trudeau
Hello all, I had to reseal a Felpro pan gasket last wk.  Apx. 3 mo. ago I installed the gasket dry as advised by the Mfg.-- dont you believe it. leaked inspite of flattening the flange and leaveling the bolt holes.  I used a sealer and no leaks yet.  The chain cover still has the orig. cork gasket and thats where some leakage could be comming from.  What is the oil level in the chain pan?  Openings in the wall btwn. the two pans is how the chain oil gets to the lower pan.  Is the chain lub. from the top or is it splashed from the oil in the lower pan? Anybody know, please respond.  Thanks.
