Bumper plating Factory remnants. Anyone???
Started by Andrew 10642, January 03, 2006, 11:19:11 PM
Andrew 10642
OK, now that I have your attention!!
Recently, a friend of mine purchased a pre-1900 building, approximately 10,000 sq ft, which was used for at least the past 40 years as a chrome plating facility.  Yes, its an EPA issue.
Anyway, while cruising the facility for leftover NOS Cadillac parts, I came across literally dozens of bumper templates constucted out of masonite panels, which were probably used to check tolerances when straightening bumpers.  Also, there were many Bumper Identification Manuals.
My question?  Is this stuff worth anything?  This guy needs all the help he can get, as the building requires at least $300,000 to bring back to life.
There is also a boiler and vats available, and everything is located in Columbus, Ohio.
Ask you chrome plating sources!!
