96 cadillac deville
Started by sophia, January 31, 2006, 06:59:53 PM
sophia
my car begin to shut off at the stop sign and lights if I sit for more than a few seconds.  I had a few things changed based on my computer  readings:
spark plugs changed
oil change
idle airflow motor changed
egr changed
map sensor changed
Put the car still cuts off.  I took it to a mechanic who stated my oil pressure drops to low and makes the car shut down. What can I do to fix this problem?
Rusty Shepherd CLC 6397
Id say the most likely culprit is the oil pump providing that what the mechanic is telling you about the reason for the shut-downs is true. I didnt know the Northstar engines had that provision, but they well may have. Im guessing that it will be a difficult and expensive proposition to get to the oil pump and replace it as is the case with many things on that engine.
