57 Air Conditioning A/C System Pictures & Parts
Started by Ralph Williams, CLC # 18472, December 17, 2006, 03:01:26 PM
Greetings--
I’m still trying to find parts for a ’57 Cadillac air conditioning system and pictures of an installed ’57 Cadillac air conditioning system.
I’m looking for pictures of all installed components, including the arrangement of the bracket relocating the oil filter from the passenger side of the engine to the driver’s side, how the condenser and receiver are mounted on the radiator support, and how the fan shroud is mounted.
Following are the parts I need:
- 4-groove crankshaft pulley
- Supporting brackets for the compressor
- Supporting brackets for the fan shroud
- Components necessary to relocate the oil filter (brackets, tubing, etc.)
- “Foot coolers” mounted inside firewall covering vent holes present for non-A/C cars
- Control cables that run from dash control head to evaporator and hot gas bypass valve (2 cables)
- Any ductwork, no matter what the condition.  (I’ll use bad ductwork as template to fabricate replacement--of course, good condition would be preferable)
- Air conditioning wiring harness
- Resistor for air conditioning blower
- Any other parts that might be available
Thanks.
Ralph
’55 60S
’57 60S
’59 SDV
