Cadillac & LaSalle Club Forums => Want To Buy - Cars => Topic started by: CraigD on March 11, 2019, 08:46:39 PM
Title: 1940 Emergency / Hand Brake Handle
Post by: CraigD on March 11, 2019, 08:46:39 PM
I need the Emergency / Hand Brake handle for my 1940 LaSalle Model 52. I have attached a photo of it. Mine is missing a part that holds it in place when you apply the brake.
Title: Re: 1940 Emergency / Hand Brake Handle
Post by: Jamurray on March 11, 2019, 10:58:19 PM
I have one on a 5019 that I am parting out. I don't know if they are the same, but if they are, you will have one. I'll check on it tomorrow.
Jack
Post by: CraigD on March 12, 2019, 08:11:40 AM
The body on mine is a 40-5219. Hopefully, they used the same part on both. Thanks!
Post by: Bob Schuman on March 12, 2019, 12:14:11 PM
The emergency brake handle for the 40-50 and 40-52 series show different part numbers in my 1935-1942 Master Parts Book and my 1949 book. The difference may or may not make a 50 series handle  usable on a 52 series. The book shows the same part number for 40-52, 62, and 72, but no others.
Post by: CraigD on March 12, 2019, 12:26:54 PM
Thanks Bob! I appreciate the research. I will try to make sure it will work before I get it.
Post by: Tom Boehm on March 12, 2019, 01:09:10 PM
The only possible difference I can think of would be the angle or some other difference in the mounting bracket. The series 50 and the series 52 were built on two different GM bodies even though the styling is the same. That is why a different brake handle/part number may have been necessary.
Post by: holydagmars on March 13, 2019, 12:32:43 PM
If I may butt in here . . . if it develops that the 50-series handle does not interchange with the 52, a possible alternative source might be a different GM make using the same "C" body as the LaSalle 52, such as Buick 50/70 series, Olds 90, and of course, Cadillac 62.
Post by: CraigD on March 13, 2019, 12:36:41 PM
A good idea Charlie. Thanks!
Post by: DaveZ on March 29, 2019, 11:28:07 AM
What part do you need? We have one if you are still looking. Off a 5219.
Dave
Post by: CraigD on March 29, 2019, 11:39:36 AM
Hi Dave,
I need the whole brake handle assembly. (See photo) It's all one assembly, and I don't think the missing part that I described is supposed to be removable, so I would like to get the whole assembly. Please let me know how to contact you and we can make arrangements. Thanks!
Craig Duerling
email: Craig at Duerling dot org
Post by: jwaldrich on April 14, 2019, 01:26:53 PM
I believe I have one if you are still looking. The attachment point is bent but can be heated and straightened. Or maybe it is suppose to be bent... I don't know.
See Attached.
Post by: CraigD on April 14, 2019, 01:36:58 PM
Thanks John. I very recently found one, but I really appreciate your response. This forum is an amazing resource!
Post by: jwaldrich on April 14, 2019, 01:41:22 PM
Quote from: CraigD on April 14, 2019, 01:36:58 PM
You are most welcome.
Post by: Tom Boehm on April 14, 2019, 05:12:42 PM
The mounting bracket is supposed to be that way. Yours is OK.
