1974 Coupe deville questions
Started by Ville, June 30, 2015, 06:12:09 AM
EAM 17806
1974-1976 Cadillac deville cars all came from the factory with radial tires as standard equipment. The factory shop manual states to set the tire pressure in accordance with the specifications on the placard label which is located on the inside of the glove box cover. It states there 23 psi in the front and 24 in the rear per the 1976 factory shop manual on page 10-2. However, for continuous high speed driving over 75 MPH increase pressure 4psi up to a maximum of 32PSI, but for average driving I suggest 27-28PSI on all fours; remember these three years are basically the same body and weight. Again, this is from the factory shop manual.  EAM
Ev Marabian
Ville
Yes i have radial tires.
Okay i buy that shop manual at least. What fisher body manual includes what shop manual doesnt?
CDV 1974
Ville
What is basic adjustment of idle mixture screws? I mean turns.
I have vacuum gauge which helps adjustment but its too rich. How accurant is mixture screw? Is 1/4 turn accuracy ok?
Emission tag says co 1% max is that true? If i go to smog test. Its not must in there because car is old but id like to know mixture.
CDV 1974
"It states there 23 psi in the front and 24 in the rear per the 1976 factory shop manual on page 10-2. However, for continuous high speed driving over 75 MPH increase pressure 4psi up to a maximum of 32PSI, but for average driving I suggest 27-28PSI on all fours; remember these three years are basically the same body and weight. Again, this is from the factory shop manual.  EAM"
That is old and outdated information, unless maybe you are still running radial tires built back in that time period.  Radial tires have continued to evolve since then in construction and technology, and I stand firmly behind what I have said.  Your car, your tires, do what you will.
I did try running mine that low and it didn't really seem to soften the ride but made the handling seem extra soft.  Also noticed they seemed to run a lot hotter even at moderate speeds.    Take em up to the tire max of 45 and the ride does get really bad but in the 30-35 range I didn't think the overall crusing comfort was much different than in the 25 range.
bill06447
it sounds like the rubber body mount bushings may have deteriorated, and the body is riding directly on the frame, might want to confirm the body mount integrity.
Bill
Ville
Ill check rest of these. I've already checked from because it rattles. It was caused by windshield which is off on bottom at least, maybe sides too.
By the way, I hear that same aged Lincoln were the most smooth cars on road. Is Cadillac smoother than Buick,Chevy,olds or mopars? Just thinking...
Does shop manual include nothing about a/c troubles,or do I have to order Cadillac Tim troubleshooting guide too?
CDV 1974
The shop manual does have info on the climate control system.   The difference between that and Tim's book is that Tim wrote his like 10 years ago based on his current experience repairing the systems so his book focuses on what usually fails or needs attention at this age.  His book also does not require the special dealer type tools.
Ville
CDV 1974
Ville
Can someone help and tell which colored wire is for headlights? That what is visible link to start ->
I've replaced all fusible links from start but headlights are tricky. Yesterday they started to work when I re check links under car. Today they suddenly went off.
Maybe fusible link wire is bad or switch?
If link is little bit too small, can it cause that kind of problems? All links are fine, no burn or voices when I touch those.
CDV 1974
G'day Ville,
You have an email that requires your immediate attention.
Bruce Reynolds
CLC # 18992
Message Board Administrator
Ville
Sorry Bruce! Im lazy what comes reading emails.
Hope all is now okay?
Good day too even in there Finland clock is 4.12 a.m  ;D
CDV 1974
Good job Ville,
So you also missed my email about the $9 Million that you won the other day? ;)
Down here in Tasmania, it is 11.14am, Wednesday.
Ville
Heh.
Been some pause for cadillac.
Automatic level control hoses are now stucked. Now vacuum gauge won't wobble anymore.
But! I can't get more than steady 15-16hg. Timing is ok and new dist cap etc. What can cause it? Works still good.
Also measured acceleration with GPS today. 0-100kmh (about 62miles?) was 9.1 seconds, woah! 0-80kmh 6,1. I'm surprised.
But over 100kmh/60miles it will slow down and I see the limitations of big car.
I inspected car too, first time in my country. Was good and passed. Shocks are bad because test gives only 50%.
Rear are still air shocks but hoses are cutted off. Is it possible to fit new hoses and try them?
CDV 1974
Ville
I removed dash covers and panels. Now I can switch bulbs etc. But main fault is somewhere else. Won't  give 12v in sockets. Can faulty light switch / dimmer cause that? Fuses under dash ok.
Removed a/c temp sensor too. Now it gives only heat. So that means my sensor is working because,I can adjust temp when its on. Only a/c cool is missing.
All warning lights should go on when power is on before starting?
CDV 1974
Ville
Is there some place in engine where i can but coolant temp sensor for gauge?
CDV 1974
Ville
CDV 1974
64\/54Cadillacking
Quote from: Ville on July 03, 2015, 08:40:43 AM
Maybe not in the 60's, but In the 70's, this is generally true. The Lincolns were smoother riding cars that felt like you are on cloud with Zero rattles, as their suspension was tuned more for comfort and softness rather than for handling more so than a Cadillac. The bodies are better constructed not just the way the frame and body mounts are designed, but the actual quality of construction of the BODY itself. The doors, the hood, the cabin, rear sail panel. Panel welding, the strength and torsional rigidity of the metal, all that contributes to a more solid more comfortable ride. It's not just the suspension setup, but the actual construction of the entire car is what makes for a great ride.
I used to own a 72 Cadillac Sedan Deville that is exactly the same car of your 74, and that car rattled, shook, and shivered over rough pavement. I was very surprised by this for it being a Cadillac. Even with shocks and control arm bushing replacement, new tires with an alignment, new steering components, the car still rode rough. The quality of this year was terrible IMO compared to the older models.
I heard that from 71-73, these particular model Cadillacs had body integrity issues. Because I remember riding in a 70 Cadillac years ago, and that car was amazingly smooth, quiet, and comfortable.
Currently Rides:
1964 Sedan Deville
Previous Rides:
1987 Brougham D' Elegance
1994 Fleetwood Bro
1972 Sedan Deville
1968 Coupe Deville
1961 Lincoln Continental
Ville
Okay, lincoln is winner in smoothnes. So many has told that  :(
How about in other marks? Or i just wanna know which place cadillac gets in smoothnes? I had 74 impala stw which feeled same but rear leaf springs stiffered bouncing a lot i think.
CDV 1974
Ville
Clock is not working because one little red pinion is broken, just besides the clock "motor".
Does someone sell those anymore or do i have to get whole "new" clock?
CDV 1974
