'61 Cadillac 390 Oil Pump Bolts & Cam Gear Bolts... HELP!!
Started by NZSUTTON, November 18, 2019, 02:49:46 PM
NZSUTTON
Building a '61 Cadillac 390 and in need of oil pump bolts and cam gear bolts ASAP.  Anyone know where I can buy some or have specs of bolt sizes needed?
Thanks so much for the help!!
Nathan
nathanzsuttonemail addresses not permitted
Big Fins
The FSM shows size and torque specs, but not the length.  :P
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
NZSUTTON
Quote from: Big Fins on November 18, 2019, 05:26:12 PM
Any chance you can share that info?  I don't have a FSM unfortunately.
Thanks so much.
Big Fins
Cam sprocket 5/16-18, 15 ft lbs Min, 18 Max.
Oil pump cover to body 1/4-20 40 In Lbs min 45 Max.  This is Inch Pounds
Oil pump to rear bearing cap nut. 3/8-24  25 Ft Lbs Min, 30 Max
Current:
1971 Sedan de Ville
1969 Sedan de Ville
1959 Sedan deVille
NZSUTTON
Quote from: Big Fins on November 19, 2019, 01:28:20 PM
Thank you.
cadman56
Make sure the back side of the bolts you pit in the cam gear do NOT contact the block behind the cam in any way.  I don't think they are even 1/2: long, at least not on a 56 365 engine
1967 Cadillac Eldorado (sold)
Larry Blanchard CLC #5820
Big Fins
I was going to say that I remember them being only about 1/2" long, but didn't want to give incorrect info knowingly.
Current:
1971 Sedan de Ville
1969 Sedan de Ville
1959 Sedan deVille
Daryl Chesterman
Nathan, I don't have my Master Parts List here at the house, but I do remember that the cam sprocket bolts are a grade 5 bolt and had external star washers under the heads--not sure of the length, sorry.  My 1959 390 used studs for the oil pump mount, with split lock washers and nuts to retain the oil pump to the rear main bearing cap.
Daryl Chesterman
Glen
Look at the attached, if I have it right the cam sprocket bolt is 5/16-18 and 3/4" long.
Glen Houlton CLC #727
CLCMRC benefactor #104
Daryl Chesterman
Nathan, you can see in Glen's posted parts picture that the oil pump is mounted to two studs on the rear main bearing housing.
Daryl Chesterman
