1970-472 rebuild with benefits
Started by "Cadillac Kid" Greg Surfas 15364, August 10, 2020, 07:43:35 PM
as you can see from my photo, the head has not yet been touched.  I just slid the larger valves in to show the difference.  As I previously mentioned, the block has been "decked", meaning that it has been machined as required so the tops of the pistons are exactly even with the cylinder block surface.  Since I am working on a "high compression"  1970 motor, and Cadillac themselves determined that the 10.5:1 as featured in 1968 and 1968 was a tad too high and went back down (through piston redesign) I  plan on taking just enough off the heads to raise the compression to an exact 10:1.
More will be revealed.
chrisntam
Marty told me the '70 motors were really 9.3 to 1 compression.
The sales department rounded up.
1970 Deville Convertible
Dallas, Texas
#22
9.78:1 at a 76cc chamber. Going to take a few ccs out to get to a true 10:1. With the cam I intend using a little more compression can be successfully tolerated to pick up some power.
Cadman-iac
Quote from: "Cadillac Kid"  Greg Surfas 15364 on August 18, 2020, 10:33:21 AM
Heads are in the shop and should have the results in a week or so.
Hey Greg,
Did you get your heads back from the machine shop yet? Just curious about the results of the porting job. Can you post a couple pictures of the heads too?
Rick
CLC# 32373
Rick,
Sorry to drop the ball but I got side tracked an another motor. A large chamber 500. More on that motor later, but the heads are going to the shop tomorrow or Thursday.  Should have them back as well as test results shortly there after.
Cadman-iac
 That's ok Greg,  I was just curious if you had them back yet.  Thanks for letting us/me know the status. I didn't want to miss your post about them.
Rick
CLC# 32373
Well,
I dropped by the machine shop to check on progress, and just like all shops that do quality work it is taking a bit longer than originally estimated. They have cleaned the heads and installed new valve guides.  We had a little conversation regarding the promised 2 weeks, and it should not be too long now.  Weather getting to be perfect for working outside, and my ambition is returning.
Big Fins
And this weekend, it'll be so cold outside, you're going to look out the window and curse it.
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
No John,
That comes the following week end when it will only get up to 78 on Saturday and 80 on Sunday.
Greg Suras
Big Fins
Hell...78-80 is a dream temperature. The Weather Channel is forecasting some bitter cold and snow into the DFW area with just cold down to the Houston area.
I absolutely HATE cold. I'd rather sweat.
Current:
1971 Sedan de Ville
1969 Sedan de Ville
1959 Sedan deVille
John
That’s why we moved to San Antonio. It’s hot in the summer and (a few days) cold in the winter , but none of the extremes the face DFW and Houston. Don’t tell them or they’ll move here.
Greg surfas
Didn't realize it has been that long since I started on this project.  With the heads at the machine shop for large valves and porting work I have been busy fooling around building 500 inch motors. Don't ask me what for, because you can't question an addiction.
Anyhow, just talked to the shop and we are a couple of weeks out, so I'll have all the new info soon.
