1964 Convertible - Possible Eldorado $3500
Started by Bryan J Moran, September 27, 2023, 12:51:12 PM
Bryan J Moran
https://www.facebook.com/marketplace/item/191718680219802
Yes it is a mess.  I asked the seller if it was indeed an Eldorado. Of course he said it was. I can not see any positive way to identify it as such.
CLC 35000
jwwseville60
I have a 64 Eldo.
The lower stainless trim and the rear fender crests suggest strongly that its an Eldo.
I would think the VIN tag would say a lot.
Lifetime CLC
2011DTS
#2
Brian what John sid correct the tell tell sign is the wreath and crest on the rear quarter panel. it is a Eldorado with the bucket seat option, highly desirable. But the that is a parts car. It would go well into six figures to bring it back.
Also for future reference. I know I should never say never but Cadillac from the 60's onward to the 80's only put a crest with a wreath on a Fleetwood or a Fleetwood Eldorado. The DeVilles only had the crest and never the wreath. So when you see a wreath and crest hood ornament or the crest on the trunk lock with a wreath on a deVille someone put it on there. An easy way to tell the difference on parts cars/rust buckets...
V63
Painfully... The wreath got slapped on everything about 1985 except the cimirron
marty55cdv
#4
There would of had to of been some major body work done if it wasn't an Eldo,  different rear wheel wells, trim removed holes filled etc.  Passenger door is from a Deville you can see where the trim was mounted
Marty Smith
  CLC #22760
41 60 Special http://bit.ly/1Wm0GvT
55 CDV http://bit.ly/1G933IY
56 Fleetwood
1958 Extended Deck http://bit.ly/1NPYhGC
1959 Fleetwood  http://bit.ly/1OFsrOE
1960 Series 62 Coupe
1960 Sedan DeVille  4 window Flattop
63 Fleetwood http://bit.ly/1iSz17J
1964 Eldorado http://bit.ly/1Wm17GA  (Living in California now)
1988 EBC http://bit.ly/1iSACKz
Eric DeVirgilis CLC# 8621
The full rear wheel openings without skirts is a hallmark of the 1964 Eldorado. It is the only Cadillac model from 1959 to 1964 with this feature.
James Landi
A great buy for an old geezer like me with not enough time on "my clock" to complete the resortation... one can dream.
billyoung
The definite remains of a quite loaded 1964 Cadillac Fleetwood Eldorado Convertible, RIP.
Age 69, Living in Gods waiting room ( Florida ) Owned over 40 Old Cadillac's from 1955's to 1990 Brougham's. Currently own a 1968 Cadillac DeVille Convertible and a 1992 Cadillac 5.7 Brougham.
jwwseville60
BTW, this is a car worth restoring to any level. 100%.
Lifetime CLC
James Landi
John,
If somehow this came into my life, and if it were sitting in my large barn, I'd check out the frame first for "terminal rust through" ... then, I'd do a quick check on the fluids, and see if I could manually turn over the engine.   If all this checked out, then I'd prepare for an engine start up--- always hoping that the final few miles were not driven by someone hell bent on destroying the engine and drive train...If all checks out and it runs in an acceptable manner and the transmission and drive train were in "reasonable" working condition,I'd try to figure out priorities to make it acceptable inside and out at the most reasonable prices. Here I'm thinking about James Gandolfino, Lead in The Sopranos,whose prized possession was a high mileage '68 Cadillac convertible with a top that wouldn't go up... (the NYTs ran a piece in the Magazine Sunday Section that was entitled (I think) PRIZED POSSESSIONS).  James
Bryan J Moran
Quote from: jwwseville60 on September 28, 2023, 08:15:39 AMBTW, this is a car worth restoring to any level. 100%.
Interesting and I am kind of surprised.  Few members suggest a restoration of almost any project Cadillac these days.  The oft heard "Buy The Best Car You Can" prevails.
CLC 35000
jwwseville60
1964 Eldos are very, very attractive.
You might have to find a new frame and other parts, but when you're done, a masterpiece will emerge. Just my five cents.
Lifetime CLC
