1950s 1959 Cadillac ID Tag
Started by MichaelC, January 12, 2024, 12:05:54 AM
MichaelC
Quick question
i have a 59 cadillac flatop. why are there staples in the id tag
the car is black but the paint code is showing silver
anyone help
Michael C
G'day Michael,
The plate reveals that it was a Special Option Vehicle, Hence the SO stamped into it.
The Staples would have held the cardboard listing of what the Special Option was, but, over the years, water has degraded it, and the visible paper has come off.
You will need to get the Build Sheet to see what the Special "thing" is.
PS.  You have an email from the Administrators that requires your attention.
Cadillac Jack 82
I'm curious to see what option this is as your car appears to be loaded.
Tim
CLC Member #30850
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Eric DeVirgilis CLC# 8621
Quote from: MichaelC on January 12, 2024, 12:05:54 AMQuick question
anyone help
The SO is for TRIM a/k/a interior, not the paint. The exterior color change was done later and has nothing to do with the SO. If the interior is still original, the SO might be able to be determined. Please post a good assortment of interior images.
wrefakis
build sheet usually provided will not show actual "SO"
you need the order sheet specific to that car
Cadillac Jack 82
Neighbor has a SO car.  Its a 1960 CDV in Olympic White with a burgundy interior.  Really weird but striking combo.
Tim
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Lexi
Quote from: wrefakis on January 12, 2024, 09:15:01 AMbuild sheet usually provided will not show actual "SO"
Agree. My experience is that they normally will not show SO items. Was also borne out in my case. Just the staples left. Clay/Lexi
MichaelC
Quote from: The Tassie Devil(le) on January 12, 2024, 01:09:03 AMG'day Michael,
thanks for the info where do you find a build sheet
Michael C
MichaelC
Quote from: Eric DeVirgilis CLC# 8621 on January 12, 2024, 08:48:47 AMThe SO is for TRIM a/k/a interior, not the paint. The exterior color change was done later and has nothing to do with the SO. If the interior is still original, the SO might be able to be determined. Please post a good assortment of interior images.
the inerior is just a black color
Michael C
MichaelC
where could i find all of the info please
Michael C
Quote from: MichaelC on January 12, 2024, 03:48:49 PMthe inerior is just a black color
Leather? That would be the SO.
Clewisiii
MichaelC
#12
Quote from: Eric DeVirgilis CLC# 8621 on January 12, 2024, 04:37:48 PMLeather? That would be the SO.
yes it is leather
so would the original color been silver and someone painted it black
Michael C
G'day Michael,
You still have not got it right.
Please re-read the email.
#14
Quote from: MichaelC on January 12, 2024, 08:06:39 PMyes it is leather
Leather was not a standard interior selection on DeVilles therefore special order was required to get it.  Otherwise the SO has nothing whatsoever to do with the color change which was done at some point after the car had been built.
**CLC Forum rules require a minimum of first initial and full last name to appear in your posts. Please make the necessary changes to your profile settings.
