1950s 1955 lifters
Started by Bob Kielar, January 17, 2024, 10:07:23 PM
Bob Kielar
Having trouble with noisy lifters for my recently rebuilt 1955 331. Which lifter is correct the one with the hole in the cap or no hole?
Bob Kielar
Keep Cruzin
1955 Cadillac Fleetwood
V63
#1
The one on the right appears collapsed?
I always pre lube the lifters by sinking them in oil and pumping them up until no bubbles. Then install them wet.
The hole in lifter should correspond to hollow pushrods ?
Sorry but the right one is normal as the circlip is directly over the pushrod seat.
V63
#3
Quote from: The Tassie Devil(le) on January 18, 2024, 05:23:31 AMSorry but the right one is normal as the circlip is directly over the pushrod seat.
It might be an optical illusion because of the coloration. The right one, appears in the image as the plunger is recessed?
Here is an image of a 'made in USA' lifter for the 331.
Bob Kielar
There are five bad lifters that were made in China. The one on the left is made in China the one on the right is from an original engine. Every lifter I have seen does not have the hole in the top cap is it necessary? Looking for a full set of nos or new USA made lifters any leads would be appreciated.
Bob Kielar
Keep Cruzin
Do you have shorter push rods with the lifters made in China? From your picture, the original lifters used a longer push rod. Ask maybe Terrill Machine if the Chinese lifters are not from him...
Cadillac Jack 82
I miss the days of quality parts that weren't outsourced to some shotty production facility in some far away land.
Tim
CLC Member #30850
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
5390john
1955 CDV "Marilyn"
"Panic Accordingly"
Bob Kielar
Thanks John,
Ordered a set of lifters from Egge while their camshafts are made in the USA their lifters come from Elgin Illinois and they get them from China had to send them back.
Bob Kielar
Keep Cruzin
Talking to an engine rebuilder friend the other day regarding the Chinese ones, he says he re-radiises the originals and after dismantling and cleaning, (not in that order) they are fully serviceable.
The original GM Lifters have a darker piece on material on the bottom, whereas the Chinese ones are all the same.
Plus, don't forget that without enough Zink in the oil, all lifters will destroy themselves.   Another friend has "destroyed" two engines in his cars because of the use of oil designed for modern cars.   Got to check the Zinc content.   No Zinc, no go.
This is what happens when there is no Zinc in the oil.
Notice the different heights in the lifters?   These were originally the same lengths, and the wearing away of the bases sent microscopic pieces throughout the oiling system, and embedding lots of particles in the soft layers of the bearing shells, what it is supposed to do.
PS.   These pictures are replacing those lost.
