1940 Emergency / Hand Brake Handle
Started by CraigD, March 11, 2019, 08:46:39 PM
CraigD
I need the Emergency / Hand Brake handle for my 1940 LaSalle Model 52. I have attached a photo of it. Mine is missing a part that holds it in place when you apply the brake.
1940 LaSalle Model 52 Special
1967 Oldsmobile Toronado
2007 BMW 530i
2015 Jeep Grand Cherokee Limited
Jamurray
I have one on a 5019 that I am parting out. I don't know if they are the same, but if they are, you will have one. I'll check on it tomorrow.
Jack
CraigD
The body on mine is a 40-5219. Hopefully, they used the same part on both. Thanks!
2007 BMW 530i
Bob Schuman
The emergency brake handle for the 40-50 and 40-52 series show different part numbers in my 1935-1942 Master Parts Book and my 1949 book. The difference may or may not make a 50 series handle  usable on a 52 series. The book shows the same part number for 40-52, 62, and 72, but no others.
Bob Schuman, CLC#254
2023 XT5
CraigD
Thanks Bob! I appreciate the research. I will try to make sure it will work before I get it.
2007 BMW 530i
Tom Boehm
The only possible difference I can think of would be the angle or some other difference in the mounting bracket. The series 50 and the series 52 were built on two different GM bodies even though the styling is the same. That is why a different brake handle/part number may have been necessary.
1940 Lasalle 50 series
holydagmars
If I may butt in here . . . if it develops that the 50-series handle does not interchange with the 52, a possible alternative source might be a different GM make using the same "C" body as the LaSalle 52, such as Buick 50/70 series, Olds 90, and of course, Cadillac 62.
CraigD
2007 BMW 530i
DaveZ
What part do you need? We have one if you are still looking. Off a 5219.
Dave
David Zitzmann
1932 345B
CraigD
Hi Dave,
I need the whole brake handle assembly. (See photo) It's all one assembly, and I don't think the missing part that I described is supposed to be removable, so I would like to get the whole assembly. Please let me know how to contact you and we can make arrangements. Thanks!
Craig Duerling
email: Craig at Duerling dot org
2007 BMW 530i
jwaldrich
I believe I have one if you are still looking. The attachment point is bent but can be heated and straightened. Or maybe it is suppose to be bent... I don't know.
See Attached.
Life is tough but it's tougher when you are stupid.
CraigD
Thanks John. I very recently found one, but I really appreciate your response. This forum is an amazing resource!
2007 BMW 530i
jwaldrich
Quote from: CraigD on April 14, 2019, 01:36:58 PM
You are most welcome.
Tom Boehm
The mounting bracket is supposed to be that way. Yours is OK.
