Exhaust gasket questions
Started by Mowerhoarder, June 22, 2025, 09:37:12 PM
Mowerhoarder
Hello good people of the internet, I have a question (again) about my 51' caddy. Is it supposed to have a gasket where the manifold meets the exhaust? I know the crossover pipe has two on either side and I assume that this one would too but mine doesn't. If it is supposed to have one, where in the world would I find one? Is it a universal thing? I am happy to report though that that exhaust leak was the only thing to go wrong on the car over hot rod power tour this year! I'm pretty sure I had the oldest original car there that did the whole thing too!
tcom2027
Yes.
https://www.ebay.com/itm/146213210769 or
=91a7a476d74b169f0b9bcc2e0418ab3d&utm_source=bing&utm_medium=cpc&utm_campaign=Shopping%28BSC%29&utm_term=1100003048233&utm_content=Cadillac
Olsens' Gaskets (360) 871 1207
Davidcamper
Bigger question is why was it missing? Hmmmm
Warren Rauch #4286
#4
     Cadillac made these gaskets a little confusing to the computer catalogs of today.
  You need a Fel Pro LB 8935. Cadillac group 9.0241 part#145 4222
  fits 49-51 all ,52-56 right side of the dual exhaust.
  The left side gasket was used by most models to 1967 single or dual exhaust.
  I checked eBay . You can order a kit for say 1955 models, that contains it,but includes gaskets you can't use. I would try to match it up at a parts store. Some Fel Pro kits that likely contain it MS 8932B (49-51),MS 9143B (52-55) and MS 9330B (1956-62) Best to check whats pictured in set.
Warren
Mowerhoarder
Awesome! I work at an autozone so I should be able to match something up. Thanks so much!
